Broken front drive shaft universal - JeepForum.com
 3Likes
post #1 of 16 Old 06-15-2017, 08:58 AM Thread Starter
Leckbass
Taking a leisurely drive to the gas station this morning...
I hear: clunk clunk clunk and the front drive shaft universal joint, where it meets the transfer case broke.
It seems like the Yoke straps came off.
Leckbass is offline
post #2 of 16 Old 06-15-2017, 09:00 AM Thread Starter
Leckbass
time to put the lift kit on hold and address this
jeepyj1995 likes this.
Leckbass is offline
post #3 of 16 Old 06-15-2017, 09:10 AM
puppybreath
I've seen that happen a few times when some odd bit of junk rust flake, sand or just a burr on the flange kept the end cap from seating in the yoke properly. When you snug the strap bolts, they'll get tight and even reach proper torque, but after a while the 'junk' breaks up or works itself out and you have a loose cap.
Make sure the threads are good in the yoke, inspect the strap and replace whatever shows damage.
puppybreath is offline
post #4 of 16 Old 06-15-2017, 12:33 PM
Mookdog
Looks like the bolts just came out instead of breaking. Should be fine to clean it up and make sure nothing else got damaged. Looks like you may just be out a new u-joint and some new straps/bolts. I'd make friends with Loctite!
87TPIYJ and project_mercy like this.
Mookdog is offline
post #5 of 16 Old 06-15-2017, 03:28 PM Thread Starter
Leckbass
Looking for the correct one, Moog 369? part number 4882793
or Moog 280?
any others that you would recommend?
Any step by step procedure that you would recommend?
Leckbass is offline
post #6 of 16 Old 06-15-2017, 03:41 PM
doskiez
1979 CJ7
I had this happen to me in my dump truck. Someone else drove it and was complaining about vibration and it turns out the ride height valve on the air suspension had failed and the bags were flat. That caused poor driveline angle and introduced vibration. I fixed the valve and a few days later the U joint ripped out of the yoke. I believe the bolts had loosened from the vibration. Your jeep is obviously not a dump truck but I wanted to offer a cautionary tale around stray vibrations. Just something else to check once you get it put back together.
doskiez is offline
post #7 of 16 Old 06-15-2017, 06:00 PM
project_mercy
From what I've read on this forum, they seem to recommend the Dana Spicer U-Joints. For you, I think it would be your normal 1310 u-joint, so you'd just have to decide if you wanted the greaseable or non-greaseable ones. I don't know what people's stance here on that is. Hopefully one of them will comment.
With your help I will resist the urge to buy a chrome grill guard for yet another day.
project_mercy is offline
post #8 of 16 Old 06-15-2017, 08:01 PM
Mookdog
I like my spicer 1310s. Went in easy, smooth no issues with them. I haven't had them in long maybe a few months so I can't speak to long term durability
Mookdog is offline
post #9 of 16 Old 06-16-2017, 04:37 AM
timatoe
timatoe's Avatar
Use Spicer u-joints and get a new strap kit.
timatoe is offline
post #10 of 16 Old 06-16-2017, 07:02 AM
Mookdog
Careful with the cheap strap kits from Autozone. I bought new ones thinking I was smart and a bolt sheared off while I was torqueing it. Luckily a drill and EZ-Out saved the day. Considering these fall into the "spinny thing" category of parts, buy good new ones and make sure they're torqued to spec.
Mookdog is offline
post #11 of 16 Old 06-16-2017, 03:07 PM Thread Starter
Leckbass
my buddy just dropped off 2 Moog universal joints 280 that fit the YJ.
I know many people recommended the Spicer comma but I have these here and I've always liked Moog products too so I'll give them a try
Leckbass is offline
post #12 of 16 Old 06-16-2017, 06:46 PM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
Don't blame the strap/bolts. It's just poor maintenance. Crawl under now and again and check things out, see whats loose, snug up critical bolts (like those).
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #13 of 16 Old 06-17-2017, 07:53 PM Thread Starter
Leckbass
The first thing I checked was the other ones...
Leckbass is offline
post #14 of 16 Old 06-19-2017, 02:47 PM
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
Seeing how dirty the trunnion is I would bet the cap has been off or loose for a while. New joint, straps, Loctite you are back in business.
YJ 350TPI NV4500 HPD60 14BFF ARB Chromo's
March 2017 YJOTM
87TPIYJ is offline
post #15 of 16 Old 06-20-2017, 09:36 PM Thread Starter
Leckbass
All back together and fixed, I ordered the Spicer U joints in case something happens next time. Thanks for your help
Leckbass is offline
