-   -   Broken Bleeder for Clutch Master Cylinder (http://www.jeepforum.com/forum/f12/broken-bleeder-clutch-master-cylinder-1407549/)
PiTRiFF 08-20-2012 07:48 AM
After replacing the Clutch Master Cylinder on my 91 YJ I broke the bleeder that comes out of the transmisson. I was so careful in my attempts and think at this point I own stock in PB Blast. There is an inch of tubing that sticks out of the transmission and then the valve itself. Is it as simple as cutting that piece off and replacing it?
TheSmanman 08-20-2012 08:42 AM
Yes, If you have enough sticking out of the trans, just use a compression fitting and extend the line a few more inches, then use some type of adapter to put a new bleeder on the new line.
PiTRiFF 08-20-2012 11:29 AM
Well its good to know its possible. Im assuming the line is the same size as a break line. I found Brake Bleeder valves at Quadritech but now just need to figure out an adaptor. thanks for the advice
kahanabob 08-20-2012 01:19 PM
on my 92 the block the bleeder nipple screws into is threaded onto the line coming out of the tranny. in other words if the bleeder nipple breaks off you could take off the block it screws into and replace it along with the bleeder nipple. is yours not like that?
PiTRiFF 08-21-2012 12:13 PM
Mine looks like thishttp://voodoobrother.com/voodoo/wp-c...8/85357212.gif
kahanabob 08-21-2012 12:18 PM
same as mine, so is the bleeder screw broke of at that round block? if so you can see the round block unscrews off the line. can't you just replace the round block and a new bleeder screw? or is the threaded part of the bleed line mucked up?
PiTRiFF 08-22-2012 09:21 AM
That sounds like the best bet. I've been looking all over the place trying to find that block but no luck. Im not sure if I can get that old one off. Its really rusty.
kahanabob 08-22-2012 11:23 AM
soak it with liquid wrench first. use a open end wrench as opposed to crescent wrench. once you get it off you might be able to get the bleeder nipple out with a easy-out.
TheSmanman 08-25-2012 03:42 PM
1 Attachment(s)
Do this,. (see picture) Remove the small drum. Drill out the bleeder and the use a bigger bleeder. Get the bigger bleeder from a parts house. You'll need to tap for the bigger threads for the new bleeder. Let us know how you make out. Should be an easy fix.
copleydad 08-25-2012 03:58 PM
I tried finding that part a few years ago and found out it only is available with a new slave. In my case, the line holding the bleeder sprung a leak from hitting some road debris. I just used a couple compression fittings with a threaded cap and haven't had any issues. I used a piece of steel brake line to get me enough length in order to be able to bleed the system.
http://i855.photobucket.com/albums/a...bledrepair.jpg
TheSmanman 08-25-2012 05:50 PM
[QUOTE=copleydad;14073304]I tried finding that part a few years ago and found out it only is available with a new slave. In my case, the line holding the bleeder sprung a leak from hitting some road debris. I just used a couple compression fittings with a threaded cap and haven't had any issues. I used a piece of steel brake line to get me enough length in order to be able to bleed the system.
That's what I had suggested a few posts up, but haven't heard how he made out!?
PiTRiFF 08-26-2012 06:39 AM
sorry guys I've been slammed at work and haven't replied. I'm going to try this today. I'll post back my results
PiTRiFF 08-28-2012 07:02 AM
Ive tried everything to get that fitting off and it just wont budge. I took a baby food jar filled with PB Blast and had the piece soaking in it overnight. I put a washer and string thhrough the cap to hold the jar in place and evern that didnt work. Im going to cut that fitting off and go with the compression fitting idea from above. When picking up fittings is there a certain type I need as far as pressure rating?
TheSmanman 08-28-2012 11:01 AM
No, a compression fitting is a compression fitting they don't have different pressure ratings. You won't have any issue doing is this way. Just make sure they are tight, but don't over tighten them. You'll feel it. Let us know how you make out.
PiTRiFF 09-03-2012 04:10 PM
IT'S Fixed. I got a few compression fittings from the auto parts store and a threaded cap from home depot. The Flaring tool I got from Advanced Auto was a piece if garbage. when I finally got my hands on an old one my buddy had the task was simple. Thank you all for all of your advice and patience.
The time now is 05:11 PM.
