Broke off shifter knob..... - JeepForum.com
post #1 of 10 Old 09-15-2013, 08:07 AM Thread Starter
Rich G
So I was attempting to replace the transfer case shifter knob and when I went to remove it I broke the knob off at the thread.
Now I just have a little nub sticking out, ideally I would like to replace that shaft but does anyone else have any opinions on how to handle it?
Thanks
Rich G is offline
post #2 of 10 Old 09-15-2013, 08:42 AM
Old4X
1990 CJ7
Weld a new threaded shank on it.
YJ owners are required to own welders in 26 states now.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #3 of 10 Old 09-15-2013, 08:47 AM
brentd711
Replace the shifter, weld on a piece of 3/8-16 threaded rod or drill & tap. I went with D&T and it has held up fine for over a year.
brentd711 is offline
post #4 of 10 Old 09-15-2013, 09:29 AM Thread Starter
Rich G
I own a welder that's no problem, it just seems easier to replace the shifter.
How do they come out?
Rich G is offline
post #5 of 10 Old 09-15-2013, 09:32 AM
Old4X
1990 CJ7
Depress the spring clip on both sides and pull up
Old4X is offline
post #6 of 10 Old 09-15-2013, 09:33 AM
tom_sprecher
By loosening some torx, how else?
Actually you have to remove a couple of nuts at the trans shifter and about 3 or 4 other bolts, take the linkage off the T-case shaft and it will drop out.
Tom
tom_sprecher is offline
post #7 of 10 Old 09-15-2013, 10:22 AM
bigbossd1030
He said his shifter broke off, you don't have to remove any of this to take the shifter out of the housing.
Remove the cover plate and shift boots. Pull the rubber seal up the shaft. Now you will see a disc that is spring loaded. Push down on it, moves in and out? That's the one. Now you will notice two nubs on the shift housing. One on the left and one on the right. These lock that disc in place. Now you need to press it down as far as it will go and turn it counter clock wise about half an inch or so, it will pop up and you can then remove the shaft by simply pulling up. I find it easier to use two flathead screwdrivers to turn the disc. I have fat thumbs.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #8 of 10 Old 09-15-2013, 10:45 AM
tom_sprecher
Actually he said,
Tom
post #9 of 10 Old 09-15-2013, 10:55 AM
bigbossd1030
Actually he said,
You are absolutely correct! My apologies!
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
I am on channel 33.
post #10 of 10 Old 09-15-2013, 11:07 AM
Old4X
1990 CJ7
Does the OP have a copy of the factory maint manual?
Old4X is offline
