Broke my turn signal switch - JeepForum.com
post #1 of 21 Old 07-25-2010, 02:16 PM Thread Starter
timbertiger20
Can anyone tell me the easiest way to fix it? Do I need a whole new steering column? And if I can buy the parts.......where?
First ones fuzzy but there is part of the threads still inside and the plastic housing it screws into broke as well.
http://irregulators.com/My%20Picture...p/100_0979.JPG
http://irregulators.com/My%20Picture...p/100_0978.JPG
timbertiger20 is offline
post #2 of 21 Old 07-25-2010, 03:44 PM
Mazdarx
You can replace just that part, but it involves pulling the steering wheel and dismantling the column.
-My business, being self-employed rocks.
91 Yj Renegade, lifted, built 4.0L, 33's etc
Mazdarx is offline
post #3 of 21 Old 07-25-2010, 04:56 PM Thread Starter
timbertiger20
Where can I find the internal black plastic piece that the turn signal knob sits in?
post #4 of 21 Old 07-27-2010, 07:37 PM Thread Starter
timbertiger20
nobody?
post #5 of 21 Old 07-27-2010, 07:40 PM
DickeyeFab
They are the same as cherokees....just get one from a yard
DickeyeFab is offline
post #6 of 21 Old 07-27-2010, 09:11 PM
Hillbilly Jeep
you can get it at advance auto or napa... i replaced mine from napa i think... had to take the column clear apart but no biggy
Hillbilly Jeep is offline
post #7 of 21 Old 07-27-2010, 11:06 PM Thread Starter
timbertiger20
I was told the little plastic piece inside that is cracked is no longer available by the jeep dealer
post #8 of 21 Old 07-28-2010, 09:00 AM
MWguy101
If you have to buy the turn signal switch, bite the bullet and go to a dealer to get a good one. I got one from autozone and it fell apart on me fast. I had to return it and get a dealer one. It could cost around $150 but you will be happy you did.
95 YJ, 4" RC lift, 33x12.50x15 Durtrac
MWguy101 is offline
post #9 of 21 Old 07-28-2010, 09:53 AM
bhartwell59
1987 YJ Wrangler
$27 turn signal stalk... check this out:
Jeeps Are Us: Jeep Cherokee or Wrangler Turn / Wiper Delay switch
4.2 '87 yj, 300,000+ miles, mopar mpi, 33" bfg mud KM2, skyjacker 4", 3.73 gears, arb lockers-f and r., tom wood's 2.07 sye conversion, tom wood's hd driveshaft, magnaflow cat/custom exhaust, 4wd rear bumper/swing-out tire carrier
bhartwell59 is offline
post #10 of 21 Old 07-28-2010, 10:12 AM Thread Starter
timbertiger20
Dealer quoted me $70 for the switch............but the little piece of plastic was the problem.
post #11 of 21 Old 07-28-2010, 10:30 AM
computerguy
The turn signal stalk broke off on mine last night. any idea of how to get the broken piece out? Does it thread into the column?
computerguy is offline
post #12 of 21 Old 07-28-2010, 10:34 AM
Destr0
Anyone have a diagram or pictures of taking the column apart? I need to replace my turn signal cancelling cam but I have never taken apart a steering column before... I have heard I need a steering wheel puller, but is there any way around that or should I see if the parts store tool rental has one. I don't really want to buy one as I have gone 36 years of my life without one...
Destr0 is offline
post #13 of 21 Old 07-28-2010, 11:13 AM
DickeyeFab
You can get the wheel off without a puller, but its easier with one. There is a tool you will have to rent or buy to get the collar off to get to the turn signal cam. It uses the center shaft and pushes the outside of the ring down so you can take a snapring off. Then you can get the assembly to pull up and out of the way. Its a PITA bigtime...I would rather take an asswippin lol
post #14 of 21 Old 07-28-2010, 11:48 AM
Destr0
I have a FSM and it kind of looked like a PITA. I will probably just keep turning that signal off manually until something else breaks in the column. :-)
I certainly have other, bigger problems at the moment with it!
Destr0 is offline
post #15 of 21 Old 07-28-2010, 02:13 PM
computerguy
does the turn signal stalk screw into place or does it fit into a notch?
New turn signal switch, no left signal? sasquachYJ YJ Wrangler Technical Forum 4 01-25-2010 10:07 PM
Well I broke my turn signal lever . . . ElvisV04290 YJ Wrangler Technical Forum 16 11-21-2007 05:12 AM
Turn signal lever broke, help Johnny World YJ Wrangler Technical Forum 7 10-16-2007 01:52 PM
Broke my turn signal please help!!! markdonnell1975 TJ Wrangler Technical Forum 3 07-15-2005 08:23 PM
turn signal broke randy33876 YJ Wrangler Technical Forum 1 10-02-2004 08:29 AM
