broke my first axle... - JeepForum.com
post #1 of 18 Old 04-21-2001, 02:38 PM Thread Starter
Tonka
2015 JK Wrangler
Well, I broke my first axle yesterday, the wheel fell off and every thing, killed the brakes, etc.,etc. I need advice on replacement axles. I have the dana 35c with a powertrax lock right Cost is my limiting factor, but i don't want anything weaker than stock.
thanks in advance.
98 TJ
90 MJ short bed converted to 4x4
90 XJ 2 dr 4x4
Tonka is offline
post #2 of 18 Old 04-21-2001, 06:56 PM
FLHT_FXRS_YJ
FLHT_FXRS_YJ's Avatar
What the ^*&( happened? Is this the axle you just got finished putting the locker in?
89' YJ - 4.2 - NV4500 - NP231w/sye - 1" Body Lift - 2 1/2" Rancho Suspension Lift - 31" Firestone MTR - AR Outlaw II - Tomken Bumpers F & R - Warn 8000 front - Warn 6000 rec. mount rear - FlowFit Seats - Tom Woods Rear & Custom 2" front driveshafts
FLHT_FXRS_YJ is offline
post #3 of 18 Old 04-21-2001, 10:37 PM Thread Starter
Tonka
2015 JK Wrangler
Sure is, fatigued axle, I guess. Oh well, I just need to find a quick replacement at a good price. This is my only vehicle. It is a dana 35c.passenger side
98 TJ
90 XJ 2 dr 4x4
Tonka is offline
post #4 of 18 Old 04-21-2001, 11:40 PM
osburn
osburn's Avatar
Man, you sure have had a run of bad luck lately! Honestly, I think your housing is bent dude! I suggested that when your spiders went. I'll contact you privately to see if I can't help you locate a shaft.
Matt Osburn
Score 1032
osburn is offline
post #5 of 18 Old 04-22-2001, 12:22 AM
Cody_91YJ
Wow!
That really sucks!!
I'd really check your tubes like Osburn said.
What size tires you running on your rig???
'91 YJ Mangler w/ too many mods...and yet not enough ;)
Cody_91YJ is offline
post #6 of 18 Old 04-22-2001, 02:46 AM Thread Starter
Tonka
2015 JK Wrangler
I had 2 local trans and diff shops check out the rear. They said it was straight. Is there any way that I can check my self? By the way It's a 2.5l w ax5 trans 4.11 stock gears and 31 x 10.50 bfg mud terrains on stock steel 5 spoke wheels. Add a leaves courtesy of 2 dead 89 dodge caravans (1.5 in lift rides like stock!)
98 TJ
90 XJ 2 dr 4x4
Tonka is offline
post #7 of 18 Old 04-22-2001, 03:59 AM
jeffy
jeffy's Avatar
The most common way to break the axle shaft is with a locker. Breaks the shaft right after the splines where the shaft tapers down to fit into the carrier. Happens when you hop a tire.
A friend broke his shaft the same way and like you it look out the brakes. The cheapest way to fix it is with salvaged parts. Otherwide you could get aftermarket shafts. Not the Super 35 kit but replacement shafts. They are about 30% stronger then stock. Or so they say. They harden the shafts deeper then Dana does. If you look at the shaft where the break is you can see the hardening isn't that deep.
Good luck with the repair.
*** www.4BangerJP.com ***
jeffy is offline
post #8 of 18 Old 04-22-2001, 03:31 PM
Cody_91YJ
I think Jeffy is talking about Superior Axles Super 35C kit.
It will give you much stronger shafts plus a detroit locker.
Only downside is that its about $1000 and for that price, you could nearly do an axle swap and have a much stronger setup.
post #9 of 18 Old 04-22-2001, 06:53 PM Thread Starter
Tonka
2015 JK Wrangler
Thanks for all of your help. It's nice to have people out there willing to help.
I'm trying to find salvage parts, but no luck finding a wrecked jeep in s/e michigan
98 TJ
90 XJ 2 dr 4x4
Tonka is offline
post #10 of 18 Old 04-23-2001, 01:49 PM
rayray
rayray's Avatar
Tonka & others,
The super 35 kit is a nice setup. I've been running it for some time and have never had an issue. That's not to say that I won't. The major downfall to the setup is you can't buy spare shafts without an act of God. I've been going round and round with Drivetrain Direct and Superior about this. The reason from Superior is because they won't split up the kit. Sounds like BS to me. Also, they say that they have never had a shaft break. Just bend. Well, I'm a sceptic and I'm going to continue to try and get a spare somehow. But I will say this, they really are as strong as they claim. I've done obsticles where D44's shatered and the my piss ant axle held together.
Earth First! We can wheel the other planets later
rayray
rayray is offline
post #11 of 18 Old 04-23-2001, 01:59 PM Thread Starter
Tonka
2015 JK Wrangler
I cant afford even a new axle, I'm trying to find a used one with no luck so far. passenger side Dana 35 c-clip
98 TJ
90 XJ 2 dr 4x4
Tonka is offline
post #12 of 18 Old 04-23-2001, 02:05 PM
rayray
rayray's Avatar
here's drive train direct
(888) 584-4327
Drivetrain Warehouse
(888) 432-7656
rayray
rayray is offline
post #13 of 18 Old 04-23-2001, 03:17 PM
93YJ
Rusty's offroad sells factory style replacement shafts for the D35 that are supposed to be quite a bit stronger than factory. They are made by Superior Axle and can be found at:
http://rustysoffroad.com/driveline.html#Shafts
GOOD LUCK!!
93YJ is offline
post #14 of 18 Old 04-24-2001, 02:53 AM
jeffy
jeffy's Avatar
I'd ask someone who's gone with the Superior or Wark kit and see if they still have rigth shaft still intact.
There was a guy on ebay.com who was selling Dana 35c shafts. There was a left and a right so you don't have to buy both.
jeffy is offline
post #15 of 18 Old 04-24-2001, 12:16 PM Thread Starter
Tonka
2015 JK Wrangler
The only people that I know drive stock jeeps.
98 TJ
90 XJ 2 dr 4x4
Tonka is offline
Broke an axle Sakis94Wrangler YJ Wrangler Technical Forum 16 02-17-2009 01:41 PM
Broke my axle first time out KyleS YJ Wrangler Technical Forum 12 12-18-2005 07:10 AM
Axle help....I broke it PsychoRNGD YJ Wrangler Technical Forum 7 08-26-2005 07:03 PM
Broke my BACK AXLE! :( Rudi TJ Wrangler Technical Forum 14 06-21-2004 12:23 PM
Ford 8.8 axle broke bpavlov YJ Wrangler Technical Forum 4 12-02-2003 11:04 AM
