Breather Filter? - JeepForum.com
post #1 of 11 Old 04-03-2007, 09:44 AM Thread Starter
FSTG60MAN
Breather Filter?
On the rear of the valve cover on an 88 yj with the 2.5 there is a black plastic box that is attached to a hose that runs to the air box. What does this do? It seems to have some type of filter in it. The part is no longer available from the dealer and I can't get one aftermarket as far as I know. does anyone know what function this part serves? thanks
sold the zj back in a yj, skyjacker 7000 absorbers, bfg 31x10.5x15 all terrains, hella lighting, highlift and more tow straps than god.
FSTG60MAN is offline
post #2 of 11 Old 04-03-2007, 11:41 AM
atomicmoose
Just call me Moose
atomicmoose's Avatar
To filter the air coming out of the crank case vent...If you follow the line, it should connect to the air cleaner on the inner side of the filter. Therefore, that air needs to be filtered before it is sucked into the intake.
atomicmoose is offline
post #3 of 11 Old 04-04-2007, 09:13 AM Thread Starter
FSTG60MAN
So I guess it would have nothing to do with separating oil out of the air coming into the air box. trying to troubleshoot a blow by problem. Thank you for the info
post #4 of 11 Old 04-04-2007, 08:18 PM
atomicmoose
Just call me Moose
Do you still have the stock air cleaner setup?
post #5 of 11 Old 04-05-2007, 11:33 AM Thread Starter
FSTG60MAN
Yea, the engine is all stock
post #6 of 11 Old 04-09-2007, 08:25 AM
atomicmoose
Just call me Moose
It should have a little cup there that will catch oil that heads towards the intake. Does it have oil in it?
post #7 of 11 Old 04-11-2007, 02:22 PM Thread Starter
FSTG60MAN
the air filter is soaked and the air box is dripping
post #8 of 11 Old 04-11-2007, 03:13 PM
atomicmoose
Just call me Moose
Then you have very bad blowby most likely. Have you replaced the PCV valve of late? It may be clogged.
post #9 of 11 Old 04-12-2007, 06:58 AM Thread Starter
FSTG60MAN
replaced the pcv and cleaned the hoses, also installed new air filter. two days later the box was soaked again. I did a compression test and found one cylinder to be 10 psi lower than the others. Im afraid I may have a cracked ring.
post #10 of 11 Old 04-12-2007, 07:01 AM
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
Big-n-Broke-YJ's Avatar
do a leakdown test....
google will describe how to do it and what it will tell you.
10 psi difference in 1 cylinder on a compression check isn't the end of the world. the leakdown test will tell you more.
'89 Wrangler, 4.0/AW4, 106" Wheelbase, SOA, custom XJ packs, 2" Body. Front High Pinion Dana 44 w/yukon super-joints, chromo inners and outers, and a Lincoln Locker. Rear Dana 60 w/Yukon 1.5" 35 Spline chomo shafts and detroit locker. 5.38 Yukon Gears. Hydro-Assist, 39.5x18" Boggers on 15x12 RockKrawler's w/ 2.75" of backspacing. Comp cut, tube fenders, custom bumpers and rock sliders, fuel cell, CB, Stewart Warner Gauges, SmittyBilt XRC8 Winch, 140 Amp CS-144 Alternator, Electric Fan, and a cooler of beer. 3897 lbs
Big-n-Broke-YJ is offline
post #11 of 11 Old 04-12-2007, 08:18 AM Thread Starter
FSTG60MAN
Ill have to see if I can borrow a leakdown tester from one of the techs in the shop I work at. Thanks
Breather Tueb to Valve Cover Breather 02gixxersix TJ Wrangler Technical Forum 4 09-15-2008 11:37 AM
oil breather cap? YJames90 YJ Wrangler Technical Forum 8 08-11-2007 08:27 PM
K&N Square Stock Filter or Round K&N filter??? SupaJosh TJ Wrangler Technical Forum 9 09-13-2005 04:59 PM
Fram Disposable Air Filter (Same Part Number Different Filter) julietkilo TJ Wrangler Technical Forum 7 07-15-2005 09:02 PM
What's the Breather Filter for? Zeke YJ Wrangler Technical Forum 3 06-07-2002 04:21 PM
