Brass leaf spring bushings - JeepForum.com
post #1 of 11 Old 07-15-2013, 03:14 PM Thread Starter
wfterning
So I am pretty new to this whole jeep thing. Bought a 93 about 3 weeks ago. The front was making a little noise when I bought it but after taking it out a couple times the back is now making noise. I was going to buy replacement bushings, but then I thought about just making some out of brass. I work in a machine shop, it wouldn't be too difficult. I have a few questions though:
1. Will brass even work? I know it used to be done on old hot rods and a lot of drag cars use them.
2. How can I tell if I have stock leaf springs or aftermarket? The only lift on it is a 2" block.
3. Does anyone have dimensions for bushings? I can buy some and then take them back but that is kind of a waste of time.
wfterning is offline
post #2 of 11 Old 07-15-2013, 03:34 PM
Randonexplosion
Deplorable
Randonexplosion's Avatar
If you have a 2" lift block, then you are already spring over. Pics would help.
I don't see brass bushings being good in any situation on a Jeep. The bushings dampen a lot of road vibration and assist in letting your shackle move. Buy new bushings.
Randonexplosion is offline
post #3 of 11 Old 07-15-2013, 03:55 PM
Shadownwpa
get some poly and machine em out of that... or just buy them and save the effort
http://www.jeepforum.com/forum/f22/shadownwpa-91ish-yj-build-thread-1857154/
Shadownwpa is offline
post #4 of 11 Old 07-15-2013, 05:31 PM
Michaelgoesrawr
Michaelgoesrawr's Avatar
He could be talking about a body lift. But I'd agree about SOA. OP post some pictures of your front axle. Spring bushings could be the least of your worries.
Michaelgoesrawr is offline
post #5 of 11 Old 07-15-2013, 07:19 PM
Randonexplosion
Deplorable
Thread title says leaf spring bushings hahaha
post #6 of 11 Old 07-15-2013, 08:09 PM
dillonjm
2013 WK
I think he was referencing the "lift blocks"
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
post #7 of 11 Old 07-15-2013, 08:17 PM
Randonexplosion
Deplorable
I get it now. I was stuck on suspension lift...
post #8 of 11 Old 07-15-2013, 11:21 PM
timatoe
timatoe's Avatar
Just buy new bushings you can get them for about $2 each, brass will 100% be a bad idea.
timatoe is offline
post #9 of 11 Old 07-15-2013, 11:29 PM
wj4play
Wood.... Use wood
Ok ok just kidding - get rubber bushings for the springs or poly body pucks. No reason to reinvent the wheel
99 Grand, 37" and mostly factory - Raised tank and trimmed fenders etc
wj4play is offline
post #10 of 11 Old 07-16-2013, 01:16 PM Thread Starter
wfterning
update
Here's an update on where I am at. I discovered they used brass in the past on old hot rods and drag cars because they don't go off road with them. So I am going to be using poly. Now my next issue is that I don't know what brand of suspension it has. I went to the local offroad shop today to talk to a few guys. The leaf springs are not stock, don't know if it is a 2" or 2 1/2" lift but it does have the military leaf spring kit. I have Rancho shocks, so I am guessing it is going to be Rancho leaf springs, but I cant find any numbers on them. Gonna try and clean them tonight and see what I can find.
post #11 of 11 Old 07-16-2013, 05:59 PM
wj4play
Call deaver spring - they can help
wj4play is offline
