-   -   Brass leaf spring bushings (http://www.jeepforum.com/forum/f12/brass-leaf-spring-bushings-1549324/)
wfterning 07-15-2013 04:14 PM
So I am pretty new to this whole jeep thing. Bought a 93 about 3 weeks ago. The front was making a little noise when I bought it but after taking it out a couple times the back is now making noise. I was going to buy replacement bushings, but then I thought about just making some out of brass. I work in a machine shop, it wouldn't be too difficult. I have a few questions though:
1. Will brass even work? I know it used to be done on old hot rods and a lot of drag cars use them.
2. How can I tell if I have stock leaf springs or aftermarket? The only lift on it is a 2" block.
3. Does anyone have dimensions for bushings? I can buy some and then take them back but that is kind of a waste of time.
Randonexplosion 07-15-2013 04:34 PM
If you have a 2" lift block, then you are already spring over. Pics would help.
I don't see brass bushings being good in any situation on a Jeep. The bushings dampen a lot of road vibration and assist in letting your shackle move. Buy new bushings.
Shadownwpa 07-15-2013 04:55 PM
get some poly and machine em out of that... or just buy them and save the effort
Michaelgoesrawr 07-15-2013 06:31 PM
813 Attachment(s)
He could be talking about a body lift. But I'd agree about SOA. OP post some pictures of your front axle. Spring bushings could be the least of your worries.
Randonexplosion 07-15-2013 08:19 PM
Thread title says leaf spring bushings :rtft: hahaha :highfive:
dillonjm 07-15-2013 09:09 PM
I think he was referencing the "lift blocks"
Randonexplosion 07-15-2013 09:17 PM
I get it now. I was stuck on suspension lift...
timatoe 07-16-2013 12:21 AM
Just buy new bushings you can get them for about $2 each, brass will 100% be a bad idea.
wj4play 07-16-2013 12:29 AM
Wood.... Use wood :)
Ok ok just kidding - get rubber bushings for the springs or poly body pucks. No reason to reinvent the wheel
wfterning 07-16-2013 02:16 PM
update
Here's an update on where I am at. I discovered they used brass in the past on old hot rods and drag cars because they don't go off road with them. So I am going to be using poly. Now my next issue is that I don't know what brand of suspension it has. I went to the local offroad shop today to talk to a few guys. The leaf springs are not stock, don't know if it is a 2" or 2 1/2" lift but it does have the military leaf spring kit. I have Rancho shocks, so I am guessing it is going to be Rancho leaf springs, but I cant find any numbers on them. Gonna try and clean them tonight and see what I can find.
wj4play 07-16-2013 06:59 PM
Call deaver spring - they can help
The time now is 01:57 AM.
