Brand new bouncy shocks - JeepForum.com
post #1 of 6 Old 09-07-2011, 07:29 PM Thread Starter
DarthLister
Hey all--
Had my '94 YJ for 15 years. Was starting to get to where I could feel every pebble or penny I rolled over so I changed my shocks out (something I don't think had ever been done--we sure hadn't) for a set of Rancho RS5000s. I do a *little* off-roading, but most of the travel is on pavement and was told the RS5K was a good all-purpose set.
The issue: now, if I go over the slightest bump, I get a 2x-3x bounce. Also, if I hit a bump or a dip, i can hear a "thump" and the bump of whatever I ran over, no matter how small. Doesn't seem to be any shock absorption going on at all. I hate to say it, but it seems even worse than the stocks I pulled out.
There's no sway at all when I turn a corner. Just a lack of absorption and excessive bounce. Any ideas?
Thanks,
Rich
(pics of the lad coming)
DarthLister is offline
post #2 of 6 Old 09-07-2011, 07:41 PM
pasinbuy
Get on your bumper, then bounce up and down, jump off. If you car/Yj bounces any more than one up Maybe slightly down a bit depending on your weight then stops.
Your shocks are bad.
pasinbuy is offline
post #3 of 6 Old 09-08-2011, 02:53 AM
fratis
fratis's Avatar
its time to rebuild your bushings. pull your springs off and rework everything until the shackle and spring-eye move freely. you should be able to torque them to factory specs and still move them by hand.
-insert meaningless out-of-place political diatribe-
fratis is offline
post #4 of 6 Old 09-08-2011, 03:15 AM
Mark05059
and when you do torque them be sure its on the ground...
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #5 of 6 Old 09-08-2011, 04:31 AM
Louie4
What kind of suspension do you have? Stock?
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #6 of 6 Old 09-08-2011, 06:23 AM
vadslram
Dumb question but did you install them correctly?
I don't think they can go upside down anymore but if you dented them on installation you could have messed them up... or they are bad out of the box. It happens.
vadslram is offline
Rear Skyjacker Hydro 7000 shocks feel bouncy yinzerr8 TJ Wrangler Technical Forum 7 09-29-2010 06:59 PM
best brand of shocks PatriotCrawler TJ Wrangler Technical Forum 5 08-24-2007 07:22 PM
Bouncy, Bouncy Bears Fan TJ Wrangler Technical Forum 7 04-25-2007 09:17 AM
Bouncy bouncy idle? BNovak TJ Wrangler Technical Forum 2 06-17-2004 10:39 AM
Brand new shocks... budget boost? kjg26 TJ Wrangler Technical Forum 0 10-01-2003 09:17 PM
