Brakes won't bleed!!! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Brakes won't bleed!!!
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 06-14-2009, 12:49 PM   #1
doughnutdog
Hey guys...
Gonna have to bear w me, new to auto repair, but the economy has forced me to attempt things for the first time ever....I changed rotors, calipers, shoes, drums, pads....Had a guy help me bleed brakes, it seems all the air is out (yes, read up on correct order to bleed them, kept check fluid, never went dry, all that good stuff)....
I was stumped, (moreover, I should say my "car mechanic guy" was, he's insisting everything ws done "by the book"
can't figure out why have to pump brakes two, three times while driving to stop jeep....Was doing some poking around, the bleeders on the front are both facing towards the back of jeep, and "not on top"...I think I put them on backwards maybe?!?!? (right on left, left on right) If I switch them around, and rebleed, more than likely that will solve the problem, right??
Thanks guys, just need some help, not really an idea what to do, and money is tight, reall need to try to figure problem out w/o a shop visit
doughnutdog is offline   Reply With Quote Quick reply to this message
Unread 06-14-2009, 12:54 PM   #2
havasu
On permanent vacation
havasu's Avatar
Your bleeders need to be on the top, so I would reverse them ASAP.
havasu is offline   Reply With Quote Quick reply to this message
Unread 06-14-2009, 01:02 PM   #3
1992 renagade
X2 I can't tell you the number of times i've seen people do this and bring the car into a shop for repair.
Neill
1992 black Renegade
4.0L 5spd. 4:10 gears 33x12.50 BFG KM 2's A to Z fabrication front and rear bumpers and cage
1994 YJ Sahara Project Bean
2000 Jeep Cherokee Stock
AtoZ Fabrications www.atozfabrication.com
Blue Mountain Jeep Alliance www.bmja.org
Delaware jeep Association www.delawareja.com
Screw the HOA. More guys just need to start doing man things in the garage.
Originally Posted by aw12345 View Post
Jeeps are like mistresses, they take all your money, but boy what a ride!
1992 renagade is offline   Reply With Quote Quick reply to this message
Unread 06-14-2009, 03:55 PM   #4
pasinbuy
X3 Did it myself.
pasinbuy is offline   Reply With Quote Quick reply to this message
Unread 06-14-2009, 04:20 PM   #5
bustednuckles
me too. mine didn't leave the garage till they worked though. you're lucky
bustednuckles is offline   Reply With Quote Quick reply to this message
Unread 06-15-2009, 08:32 PM   #6
doughnutdog
Thanks guys....That was the problem, swapped em' out....works like a champ...Guess I don't feel TOOOO stupid, first ateempt at really any auto repair...Thanks again, guys!!!!
Unread 06-15-2009, 10:06 PM   #7
never0101
if you're not accustomed to what you're looking at, its VERY easy to overlook the bleeder orientation, it happens A LOT! now you know
1993 Wrangler - 4.0, 5 speed, Stock for now!
1994 Wrangler - 4.0, 5 speed, Stock (totalled :( )
2002 Grand Prix GTP - 12.84 @ 105 - Not Stock
never0101 is offline   Reply With Quote Quick reply to this message
Unread 02-11-2013, 07:08 PM   #8
DestiniGirl
Help!
We did the same thing and changed that the bleeders are on the top.. Bleed the brakes, everything is coming out good, turn it on and brakes goes to the floor.. Why?
DestiniGirl is offline   Reply With Quote Quick reply to this message
Unread 02-11-2013, 08:42 PM   #9
bigbossd1030
Bleed them again. Make sure they are done in the proper order. Rear ps, rear ds, front ps, front ds. If after that, you still have the same problem, I would think booster. And I have done this too.
[COLOR="DarkGreen"]/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)[/COLOR]
[COLOR="Blue"]OFFICIAL JEEPER[/COLOR]
[COLOR="Red"]Any Jeepers in Edmonton, AB
I am on channel 33.[/COLOR]
I live, I ride, I am JEEP.
bigbossd1030 is offline   Reply With Quote Quick reply to this message
