Brakes won't work - JeepForum.com
post #1 of 11 Old 03-15-2014, 11:04 PM Thread Starter
jdifede4
Brakes won't work
So I need some help. I did a brake job on my 95 yj Rio Grande. Put new calipers, rotors, and pads. After I got done and started to pump fluids my break pedal won't get stiff. So I put in a new master cylinder thinking that was the problem, and same thing my pedal will not get stiff. Did a bench bleed before installing new master and bleed the brakes to make sure all the air was out. Does anyone have any idea what it can and how to solve the problem. Stuck and need help.
jdifede4 is offline
post #2 of 11 Old 03-16-2014, 05:30 AM
festerw
festerw's Avatar
When you put the calipers on did you make sure the bleeders were on the top side. If not you won't be able to bleed all the air out.
Hers - 2011 Dodge Durango Crew
Mine - 2003 Jeep Wrangler X
1998 Jeep Cherokee Classic
festerw is online now
post #3 of 11 Old 03-16-2014, 07:58 AM
Scrmngchicken
I'm thinking lots and lots of air got into the lines.
Scrmngchicken is offline
post #4 of 11 Old 03-16-2014, 08:02 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Try bleeding from the furthest away from the MC. Passenger rear then driver rear then passenger front then driver front.
In only that order.
Luck Favours The Prepared
Anticanman is offline
post #5 of 11 Old 03-16-2014, 08:21 AM
NHfireLJ
NHfireLJ's Avatar
Problem is he worked on the breaks and not his Brakes... Sorry, couldn't resist
AUDREY...95 YJ UNLIMITED
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #6 of 11 Old 03-16-2014, 08:25 AM
jaycal3
I was thinking it but resisted the urge to be a d...... well you know... its just too easy and coffee hasn't worked through me yet!
Bleed, bleed, bleed... or you are leaking somewhere. I know you replaced the master, but make sure its seated correctly. My old master actually leaked air at the seal with the booster but it just kind of quietly gurgled and didnt really leak if that makes sense. It took a keen eye to see the issue.
93 YJ, 6 cyl,3.5" BDS,1" Prothane BL,1/2" booms, 33" Mickey Thompson MTZ on MT Beadlocks.
Do your part for Leukemia research - help find a cure.
KCCO
jaycal3 is offline
post #7 of 11 Old 03-16-2014, 08:36 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
I fixed that one too when I moved the thread. Apparently the title didn't take.
Fixed now.
post #8 of 11 Old 03-16-2014, 08:47 AM Thread Starter
jdifede4
So I bleed both sides of my BRAKES until I seen no more air bubbles. Did this more then twice. This is the first time I ever had this happen and I changed brakes quite a few times. Just nerve racking when you can't figure out what it is.
jdifede4 is offline
post #9 of 11 Old 03-16-2014, 10:25 AM
langwilliams
did you get a new master cylinder? if so do they have to be "bled"? I bought a new one for a t bird turbo coupe an had to bench bleed it
langwilliams is offline
post #10 of 11 Old 03-16-2014, 10:27 AM
jaycal3
He mentioned that he did and bench bled in the initial post...
Sent from my iPhone using JeepForum... So excuse the typos, my iPhone is challenged.
KCCO
jaycal3 is offline
post #11 of 11 Old 03-16-2014, 10:14 PM Thread Starter
jdifede4
So I was wondering if the proportioning valve or a blown fuse cause my brake peddle to not stiffen up?
jdifede4 is offline
