brakes -Is this right? - JeepForum.com
post #1 of 21 Old 07-20-2013, 12:59 PM Thread Starter
mattyrayb
My first time. Thoughts? Am I missing something?
Jeep title says '88, but everything points toward '92-'95...weird.
mattyrayb is offline
post #2 of 21 Old 07-20-2013, 03:15 PM
Mobile_Homie
Desert Rat
Mobile_Homie's Avatar
It looks good to me, but just to be sure, compare to the other side.
Mark
Smoke em if you got em!
Mobile_Homie is offline
post #3 of 21 Old 07-20-2013, 04:27 PM
superj
You a e missing some stuff. Hold on while I find the photo bucket stuff from last week when I did mine
You are missing the cable that hooks to the top and wraps around that metal quarter pie shaped piec and hooks to the piece on the bottom where the e-brake connects.
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #4 of 21 Old 07-20-2013, 04:29 PM
superj
What rear end are you running?
superj is offline
post #5 of 21 Old 07-20-2013, 04:32 PM
superj
Also, next time, wire brush everything out of the brake area. You have a lot of dust and crud built up inside your drum area that is holding moisture or fluid in there. See how everything looks wet. You can wire brush it off or use a can or two or brake cleaner.
superj is offline
post #6 of 21 Old 07-20-2013, 04:36 PM
bigbossd1030
Yup those aren't going to work right. Go to your local parts store and get a spring kit and an adjuster repair kit. Both are cheap. I think it was 50 bucks for both kits, for both sides here. They will come with everything you need, plus a few pieces you don't. Don't drive that jeep! Yet.
Sent from my iPhone, probably because I am bored at work.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #7 of 21 Old 07-20-2013, 04:36 PM
superj
One of the pieces missing is on the ground in your second picture. That is what your e-brake cable hooks to. It spins the self adjuster when you hit the brakes which in turn ratchets that little star on the rod between your back shoes and expands the shoes as they wear. The cable you are missing (the one not hooked up in my pic) connects to that and goes around that little metal pie pan piece and hooks to the top where your top springs are hooked up.
superj is offline
post #8 of 21 Old 07-20-2013, 04:39 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Yes, you're missing some stuff.
Look here.
http://www.lunghd.com/Tech_Articles/...ke_Service.htm
You have 10" brakes.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #9 of 21 Old 07-20-2013, 04:49 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Max to the rescue!!
Luck Favours The Prepared
Anticanman is offline
post #10 of 21 Old 07-20-2013, 04:50 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Max to the rescue!!
Max
Mean Max is offline
post #11 of 21 Old 07-21-2013, 06:05 AM Thread Starter
mattyrayb
I think I got it now.
Yeah/Nay?
Now I can't get my drums on...arrrgh!
Passenger side
Drivers
post #12 of 21 Old 07-21-2013, 06:09 AM Thread Starter
mattyrayb
Also is it normal for the tops of the shoes not to be sure snug? I feel like I have to keep smacking them around to center
post #13 of 21 Old 07-21-2013, 06:17 AM
UltimatE
Resident Audio Guru
UltimatE's Avatar
Yes, that is normal. The tops of the pads ride on the brake cylinder, which moves around.
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
post #14 of 21 Old 07-21-2013, 07:27 AM
Mark05059
your adjuster screws are probably out too far... turn them in and try getting your drums on.. you can adjust themfro the back after the drum is on.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #15 of 21 Old 07-21-2013, 07:51 AM Thread Starter
mattyrayb
I put the adjusters in, pulled the ebrake multiple times after each adjustment.
Drums went on.
Hopefully I'll get confirmation on the brakes and then take it for a drive
