Brakes - No pressure in pedal - JeepForum.com
post #1 of 20 Old 10-01-2013, 12:32 PM Thread Starter
jaycal3
I have a 93, 4.0L M/T and its a 3rd vehicle so it gets driven infrequently. It sat for about a week since I last drove it and when I got in it and started to pull out of the driveway the brake pedal went all the way to the floor with little to no pressure. The red "Brake" light also came on in the steering cluster. I turned the jeep off and pumped the brake and pressure seemed to come back to the pedal and when I restarted it, I lost pressure again. I am thinking its the master cylinder. I checked for fluid loss, and there are 2 sides in the master for fluid. Looking at it from the drivers side of the Jeep, the left side is empty or low and the right side is full. I see NO leakage anywhere under the Jeep. All 4 wheels/hubs are dry. I also see no leakage at the master or booster on the firewall. Thoughts? I will be doing a brake job hopefully this week and will be replacing the calipers, rotors and pads... the caliper on the front right is freezing and not releasing. Could this be my issue or part of it as well?
93 YJ, 6 cyl,3.5" BDS,1" Prothane BL,1/2" booms, 33" Mickey Thompson MTZ on MT Beadlocks.
Do your part for Leukemia research - help find a cure.
KCCO
jaycal3 is offline
post #2 of 20 Old 10-01-2013, 01:43 PM
Siva283
If it was empty its leaking somewhere and now there is air in the master too so the entire system needs to be bled at a minimum.
Ask me how I know...
Siva283 is offline
post #3 of 20 Old 10-01-2013, 07:57 PM
Mark05059
fill up the master and have someone push the pedal... might have to pump the pedal to get some pressure in it... after you get pressure have them put steady pressure on it while you look under it for dripping brake fluid... once you find that look closer to where its coming from and then fix it. Once you have it fixed you will have bleed all 4 corners
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #4 of 20 Old 10-01-2013, 09:12 PM Thread Starter
jaycal3
Ok guys, thanks for the help. I will get some fluid along with the other parts... maybe hold off on the master. I guess I have a leak somewhere from what you are both saying.
KCCO
jaycal3 is offline
post #5 of 20 Old 10-01-2013, 09:15 PM
mnewxcv
when that happened to me it was a wheel cylinder. cheap enough to replace both and call it a day. good time to replace the little things. preventative maintenance since youll be in there anyways.
mnewxcv is offline
post #6 of 20 Old 10-01-2013, 09:44 PM
rambo3489
The front smaller one should be for the rear brakes. I bet your wheel cylinder is leaking. Not the end of the world. Plus you can get new shoes back there.
89 YJ.. My first jeep and I won't let it go. ▀||||▀
Current Project: None... I disgust myself.
<a href="
THE YJ MY WAY</a>
rambo3489 is offline
post #7 of 20 Old 10-01-2013, 10:32 PM
ashland82391
Just had this problem and fixed it today. It was a small pin sized rust hole in my steel brake line. Look around and follow your lines and see if there are any wet spots along the line. If it is the line, replace it with copper.
ashland82391 is offline
post #8 of 20 Old 10-01-2013, 10:37 PM
rambo3489
What in the rusty 8.8 do you got going on up there?
Sent from my phone because I'm doing something "more important"
<a href="
THE YJ MY WAY</a>
post #9 of 20 Old 10-01-2013, 11:25 PM
ashland82391
No it was the lines on the frame. And it's not rusty! Just a crappy cover lol
post #10 of 20 Old 10-02-2013, 02:53 AM
Mark05059
this wouldn't be the copper tubing you buy off the shelf for like plumbing etc... it would have to be rated for brake lines (nicopp) since plain copper is illegal in some US states.
1998 ZJ 5.2 Auto
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
post #11 of 20 Old 10-02-2013, 03:01 AM
ashland82391
Thought that was just common sense???
You can just puck it up from any AutoZone.
post #12 of 20 Old 10-02-2013, 05:34 AM
Siva283
Never assume anyone has common sense when it comes to items like brakes.
Siva283 is offline
post #13 of 20 Old 10-02-2013, 04:13 PM Thread Starter
jaycal3
Found the culprit. Pinhole leak on the left frame rail. Master cylinder stays and brake line gets replaced. Can I get one pre bent?
Sent from my iPhone using JeepForum... So excuse the typos, my iPhone is challenged.
KCCO
jaycal3 is offline
post #14 of 20 Old 10-02-2013, 04:55 PM
Apollo12227
You can buy a few feet of brake line and a cheap bender for a few bucks at autozone. Bend it yourself. You will also need to rent a single/double flairing tool and the appropriate fitting. Pretty basic stuff, the guy at the counter should be able to help.
Are you just going to cut out the bad section and splice new line in? Or are you replacing all of it?
Apollo12227 is offline
post #15 of 20 Old 10-02-2013, 05:07 PM Thread Starter
jaycal3
Originally Posted by Apollo12227
You can buy a few feet of brake line and a cheap bender for a few bucks at autozone. Bend it yourself. You will also need to rent a single/double flairing tool and the appropriate fitting. Pretty basic stuff, the guy at the counter should be able to help. Are you just going to cut out the bad section and splice new line in? Or are you replacing all of it?
Not really sure... Easier to cut a section, but better to replace the whole thing I assume?
KCCO
jaycal3 is offline
