Brakes are mushy but work. - JeepForum.com
post #1 of 17 Old 02-03-2013, 04:19 PM Thread Starter
animal0307
First off. I am taking it in to be looked at. I just want to hear what other people may have to think.
This started when it got super cold then warm and super cold again last week. It feels like I have no assistance from the brake booster but my brakes are still working for the most part. I have to stand on them and they work. No pressure bleed off or leaks as far as I can tell. just a lot of work to stop. I cracked my brake res to look at the fluid and this is what I saw. I've already tried flushing the system. The right side it fresh clean fluid. I sucked out and wiped out all the crap I could from both sides and the left returned to that black color. I got the front flush and bled but I couldn't break the bleeders loose on the back so that's when I gave up and decided to take it in to be looked at. I've done some reading and people suggest everything from a flush to a bad seal or water in the booster. Not sure how I would go about testing the last one without just buying a new one.
animal0307 is offline
post #2 of 17 Old 02-03-2013, 05:19 PM
willawolfe
May be as simple as needing a better job done bleeding them
willawolfe is offline
post #3 of 17 Old 02-03-2013, 07:59 PM Thread Starter
animal0307
I couldn't bleed the backs as I couldn't get the bleeder to brake loose. They were seized with rust. But I'm concerned it's more than just needing flushed because it only happens below freezing.
post #4 of 17 Old 02-03-2013, 08:04 PM
bluedeval03
DOT3 brake fluid absorbs the humidity/water from the air. It is one thing that causes the discoloration of the fluid. Why it is recommended to completely replace brake fluid every x amount of miles and years.
From what your describing it could be the combination of very old contaminated fluid, and air in the lines. A shot of PB Blast on the bleeder screws over a couple of days will help them to break loose. If not, use a big pair of vise grips and have new bleeder screws to replace the old ones with. Then bleed and try
bluedeval03 is offline
post #5 of 17 Old 02-03-2013, 09:18 PM Thread Starter
animal0307
I've shot them with some Sili Kroil and gave the vise grips a shot. I didn't want to mess them up too bad so I gave up to let the sili kroil do it's thing. Where would I get new bleeders from?
post #6 of 17 Old 02-03-2013, 10:16 PM
ROTTEN
I think you can get new bleeders at advance auto. The Site says they match my 94..
Dorman #12701 $12
I'm new
ROTTEN is offline
post #7 of 17 Old 02-04-2013, 04:41 AM
Mark05059
Dorman #12701 $12
twelve dollars for bleeder screws???? just buy the entire wheel cyls for 9.99 and take the screws out.. then you got 2 spare wheel cyls that you will need eventually
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #8 of 17 Old 02-04-2013, 06:05 AM
Siva283
Originally Posted by mark05059 View Post
twelve dollars for bleeder screws???? Just buy the entire wheel cyls for 9.99 and take the screws out.. Then you got 2 spare wheel cyls that you will need eventually
x2
Ask me how I know...
Siva283 is offline
post #9 of 17 Old 02-04-2013, 07:30 AM
kjg26
kjg26's Avatar
Is get some speed bleeders...they're one way valves. Allows you to bleed them by yourself without risking sucking air back in.
Black 1993 YJ 4.0, 5 Speed
Slowly but surely getting better and better. Trailer build soon!!
kjg26 is offline
post #10 of 17 Old 02-04-2013, 08:15 AM
ROTTEN
Dorman #12701 $12
These are the speed bleeders.
You get 2!
He just wanted the bleeder
I'm new
ROTTEN is offline
post #11 of 17 Old 02-04-2013, 09:02 AM
jokerchief462
The black you discussed in the original post may have some bearing on your problem. It is com=nsistent with worn and detriorating seals in the master cylinder.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #12 of 17 Old 02-04-2013, 04:20 PM Thread Starter
animal0307
You get 2!
I'll think about those next time if I have to do this again.
Not sure what it is. She is sitting at the shop right now. Hopefully I'll hear back from them tomorrow. Hope it won't cost an arm and a leg.
post #13 of 17 Old 02-04-2013, 06:06 PM
JeremyCT
JeremyCT's Avatar
Run the engine, shut it off. Depress the brake pedal a few times. How many pumps do you get before the pedal goes rock hard? If the answer is 0, your booster is shot/leaking.
You didn't let the reservoir go empty while you were bleeding, did you? Because the symptoms you describe makes it sound like you have air in the lines. It doesn't explain the black gunk, but it would explain the hard pedal.
1995 YJ, 5spd, Forest Green, 4.0L, off road package, soft top, 230k miles and counting
JeremyCT is offline
post #14 of 17 Old 02-05-2013, 03:28 PM Thread Starter
animal0307
Took it to the shop and my rears brakes on both rides where shot. Paid way to much to have them replace the whole rear setup.
Also they thought that braking both handles on my driver's side door would make for a great bonus. Door wouldn't open so it seems they just keep on ripping on either handle. Didn't even both to tell me about it... My door doesn't like to unlock sometimes so that's why the interior panel is off. ****ing ****s.
post #15 of 17 Old 02-05-2013, 03:29 PM
ROTTEN
Go back there and give them hell!
I'm new
ROTTEN is offline
