Brakes Help Now Please!!!! - JeepForum.com
post #1 of 4 Old 02-16-2002, 04:10 PM Thread Starter
Jeep Named Thor
My pads wore out and ruined my rotor, I need someone to help me with the process of removing and adjusting the calaper. I need this ASAHFP. Please help me, I can't live being forced to ride in a volkwagon fox!! I need my Jeep back!
1994 Jeep Wrangler YJ
2" body lift
2" shackle lift
31" BF Goodrich All Terrains
Affectionately named THOR
Jeep Named Thor is offline
post #2 of 4 Old 02-16-2002, 05:29 PM
Colby Bruce
I am not sure what you need to do, but to get the rotor off do the following:
1) Jack up Jeep, remove front wheel.
2) Unbolt the caliper from the back, wiggle it to loosen up the brakes (you may have to squeeze the calipers in with large channel lock pliers or pry the brake pads with a screwdriver.
3) Remove the cotter pin and star nut from the axle.
4) Remove the bolts that hold the dust shield to the back of the rotor and pull the rotor off.
I hope this is what you needed to know, and that I remembered it correctly.
Colby Bruce is offline
post #3 of 4 Old 02-16-2002, 09:35 PM
iamthemellowman
Hey, I see you're in a bind, just don't rush this bit.. make sure to bleed the brakes properly once you're done.. air bubbles will make your new brakes as effective as bars of soap.
And soak those bleeders in wd40 too!!!! if they break you need to get new calipers. (you could theoretically drill them out. but i think i bought two loaded calipers (with pads) for 80 bucks + a core charge. it might have been less.
'92 YJ, 4.0L, rs5000, bds 2", 30" for now.
iamthemellowman is offline
post #4 of 4 Old 02-17-2002, 10:42 AM Thread Starter
Jeep Named Thor
thanks for all of your help. I got my Jeep back in one piece safe and sound. See you again, when I need to fix my rear brakes. HA!
2" body lift
2" shackle lift
Knocking: front brakes, rear brakes, drive shaft(?) Ujoints Or Drums? Help? VanBCguy TJ Wrangler Technical Forum 14 01-31-2013 07:34 AM
Replace Rear D44 Drum Brakes with Newer Factory D44 Disc Brakes? NIB-98TJ TJ Wrangler Technical Forum 18 12-30-2009 07:55 PM
95 Front brakes are dragging rear brakes lock up instantly 72RatCamaro YJ Wrangler Technical Forum 2 03-18-2009 06:25 AM
Converting rear drum brakes to disc brakes Urb4nTr0ll YJ Wrangler Technical Forum 4 05-15-2008 06:16 PM
Brakes brakes brakes....Whos got good brakes? Tacoma750 TJ Wrangler Technical Forum 20 12-17-2006 09:15 AM
