Brakes Got Weak - JeepForum.com
post #1 of 8 Old 05-03-2013, 03:08 AM Thread Starter
NODEA
Brakes Got Weak
I have an 89 YJ six cylinder and upgraded the rear brakes to discs. The brakes worked fine after the upgrade. After another few weeks, I added a 4" lift and also installed 32" tires. The transfer case, pitman arm, and sway bar links were also changed. The brakes are now weak - I can't get even get them to lock by trying. The brake lines have been bled. Any ideas?
NODEA is offline
post #2 of 8 Old 05-03-2013, 05:01 AM
dino30
Check around the master cylinder for leaks , Also you can try and rebleed the brakes . Did you change the master cylinder after going to disk brakes in the rear ? The rear disks need more pressure then the drum brakes do .
dino30 is offline
post #3 of 8 Old 05-03-2013, 11:19 AM
superj
Make sure all the calipers and pads are good too
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #4 of 8 Old 05-03-2013, 01:45 PM
tchoberg
1987 YJ Wrangler
The larger the diameter of the tire reduces the effect of the brakes due to the change in mechanic advantage of the brake system. Sort of like when you use a longer handle wrench or a cheater bar to loosen a frozen but. Longer handle (larger diameter tire) exerts more torque on the nut (brake system) making the brakes less effective than with smaller tires (shorter wrench). This is why some owners change to a double booster power brake system to 'get back' the stopping power lost.:-)
If it ain't broke, don't fix it - Don't worry, something will break soon enough for you to fix.
tchoberg is offline
post #5 of 8 Old 05-03-2013, 06:12 PM Thread Starter
NODEA
I'll double check for leaks but everything looked good initially. The rear disks and pads are new. I also removed the pressure regulator/limiter (had a brain @#%$ and can't remember the proper name) when I changed to disk brakes in the back. I'm beginning to think the pads may not be clean or the disks rusted from sitting - this should burn off pretty quickly though - it hasn't improved in 30 miles of stop and go driving.
NODEA is offline
post #6 of 8 Old 05-03-2013, 07:13 PM
4.7stroker
Install a dual diaphram brake booster. If you get one for a 95 wrangler it is a bolt in(can be hard to find).
If you get one from a Cherokee there is a little fab work.
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
post #7 of 8 Old 05-03-2013, 10:23 PM
johnqh
The master cylinder may need to be replaced.
johnqh is offline
post #8 of 8 Old 05-03-2013, 10:31 PM
phil1330
1964 CJ5
Dwayne
Do This
"Life is hard, it's harder if your're stupid"...The Duke
phil1330 is offline
