Brakes broken. Master Cylinder shot? - JeepForum.com
post #1 of 13 Old 04-30-2009, 11:13 PM Thread Starter
TheRobster
Driving to work yesterday, and suddenly no brakes.
Brake pedal goes almost all the way to the floor.
Fortunately managed to stop in time.
Topped up the fluid and got home OK. Picked up new front brake hoses as the driver side hose was quite wet.
I replaced the driver side hose today and as I was bleeding the lines I had the cap off, and noticed that with the engine running every time I stepped on the brake pedal it would shoot brake fluid straight up. Is this normal? Is my master cylinder shot?
Check out my cheep bastard Jeep mod blog.
TheRobster is offline
post #2 of 13 Old 04-30-2009, 11:49 PM
joeyrossmiller
iv got the same problem with my pedal. not quite as bad. i asked the same question earlier today and yeah the master cylinder is most likely shot. also, i called autozone to see how much one was and asked what else i should check before spendin some money and they said see if there's any water in the booster. just take off the covering and dump it out.
94 sahara, 4" rough country, 1 1/4" home made shackles all around, 33" trxus m/t, home made cai, hesco tbs, flowmaster super 40, no track or sway bars, 4.0 h/o, home made rocker guards, re-routed the trans vent
GIT R DID, GIT R DONE
joeyrossmiller is offline
post #3 of 13 Old 05-01-2009, 07:40 AM
zeus87gn
1987 YJ Wrangler
If you have your pedal back after the line replacement, then no. Your master cylinder isn't dead. Sometimes they will shoot fluid out of them if you push the pedal fast enough. It can be normal. Bleed it with the cover on and see if everything comes out Ok. If it does, you're good to go.
If the other lines are original to the vehicle, you should to replace them all. If you have lost one, the others are sure to follow. They are the next weakest link.
Handicapped license plates are not for mentally handicapped people -
"Man has not yet evolved an inch from the primordial slime that spawned him." Mark Blankfield, Jekyll & Hyde... Together again
zeus87gn is offline
post #4 of 13 Old 05-01-2009, 07:51 AM Thread Starter
TheRobster
Thanks. That is what I wanted to hear.
I have the other front I didn't replace it as I was a little disheartened last night. The rear line is coming, it is on order. Should be in today.
post #5 of 13 Old 05-01-2009, 07:54 AM
zeus87gn
1987 YJ Wrangler
So you actually have your pedal back?
It sounds like you just lost a line.
zeus87gn is offline
post #6 of 13 Old 05-01-2009, 08:16 PM Thread Starter
TheRobster
It was great for a while. but comming home from work tonight, I got the soft pedal again. I guess I will be doing my master cylinder.
Does anyone know if there is one from a Cherokee that will fit? I am really hard up for cash and the local pick a part has a few Cherokees,and a Comanche, but no YJs.
post #7 of 13 Old 05-01-2009, 08:28 PM
tomwhysy
1987 YJ Wrangler
1999 f350 booster and master fits got to redrill few holes and extend a shaft a 3.75" but it even had the same brake light sensor mount NOW i got BRAKES
if You getting soft pedal and loosing fluid u need to fix leak
master cylinder brakes sometimes but thats rare I only broked one by using linelock and forgot and hit pedal for second time before disengaging. it will disquise itself by weird pedal feel (first it will act like is braking but when you apply more pressure it will skip and be very soft with only front or rear brakes depends which part of master fails from what you say it looks like you got bad line or could be overextended caliper but that would leak too.
tomwhysy is offline
post #8 of 13 Old 05-01-2009, 08:35 PM
ufatbastehd
maybe you have some air left in the line?
ufatbastehd is offline
post #9 of 13 Old 05-02-2009, 05:26 AM Thread Starter
TheRobster
I don't think so. I bled it three times. It feels OK at first, then the pedal gets that sinking feeling.
post #10 of 13 Old 05-02-2009, 07:22 AM
MJMPC
Check and make sure you dont have a wheel cylinder leaking................
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #11 of 13 Old 05-02-2009, 11:04 AM Thread Starter
TheRobster
No fluid leaking from any of the brakes.
All the plumbing under the master cylinder soaked with brake fluid.
post #12 of 13 Old 05-02-2009, 05:08 PM Thread Starter
TheRobster
Well $30 at the local pick a part I got the master cylinder and booster from a 94 Cherokee. The booster is a little different, but the Master is exactly the same. In the process of putting in in now.
I am sure bleeding this mess will be fun.
post #13 of 13 Old 05-02-2009, 09:27 PM Thread Starter
TheRobster
Just for the record
Replacing the master cylinder fixed the problems.
It was a pretty easy swap too.
master cylinder upgrade, ok with stock brakes? muddy93 YJ Wrangler Technical Forum 3 03-14-2010 05:23 PM
No Brakes - Do I need a bigger master cylinder capone1680 YJ Wrangler Technical Forum 6 04-20-2008 10:18 AM
Help! Brakes Master Cylinder MuDD OlllllllO TJ Wrangler Technical Forum 29 11-14-2007 11:53 PM
C6 brakes, rear disk conversion, and a new Master Cylinder Grewe02 TJ Wrangler Technical Forum 8 08-29-2007 01:31 PM
Clutch, Master Cylinder, and Slave Cylinder replaced and problem not solved.... loudog3114 TJ Wrangler Technical Forum 7 08-31-2005 09:37 AM
