brakes brakes and more brakes - JeepForum.com
post #1 of 7 Old 03-03-2002, 06:43 PM Thread Starter
evilpsych
evilpsych's Avatar
hey guys.. was out wheelin last night and my brakes pretyt much faded away.. the rig's got about 120k on it now and was wondering how hard it would be to just replace the whole caliper and rotor on the fronts. I've never bled brakes before so how much trouble am I going to get myself in?
A
So he wants to go OFF-ROAD does he????
'93 YJ, 4.0, K&N filter, Borla Header, Borla Cat-Back, Hi-Flo Cat, 3 Core Radiator, D-Rings, TruckNuts, MSD 6A, LockRite Locker in D30, Magnecors, Kickass Stereo, 1" daystar, 31" BFG AT's, Homemade Rocker Guards and Front/Rear air-tank bumpers with tire carrier, 15x8 AR-767 4"BS, BDS 3.5 HD lift, AMA A/C Kit, York OBA, GoFerIt 1" MML, 8,000lb HF/MM Winch, Magellan MAP 330 GPS, PRO-2067 500ch. Scanner, oh, and a CB capable of talking to SATURN!
"The Only Thing Necessary for Evil to Succeed is for Good Men to Do Nothing." - Edmund Burke
evilpsych is offline
post #2 of 7 Old 03-03-2002, 07:16 PM
Bob K
Bob K's Avatar
Easy job. Buy a shop manual so that you will be familiar with the procedure and torque ratings. I bought rebuilt calipers about 4 years ago for 15 bucks each!! They still work great.
'87 Wrangler YJ 4.2 I6 (sorry, sold)
JuiceBox ignition
2 1/2" ProComp Lift
31" BFG A/T's
K&N Filter
Custom Rock Guards
Turbo Muffler
Rear Track Bar in the shed
Other Tricks I won't tell to just anybody!
'99 Grand Cherokee 4.7 V8
Towing Package
K&N FIPK
ProComp MX6 shocks
Borla Exhaust
Tow Hooks
Alpine CD with Infinity+iPod connect
Just getting started!
If you're not living on the edge...
you're taking up too much space.
Bob K is offline
post #3 of 7 Old 03-03-2002, 08:22 PM
AllanAlxndr
I took my Jeep to JustBrakes yesterday to get my brakes done... I would have done them myself however, I bought the Jeep used by 2 other owners and wanted it all checked out... Glad I did, but 500 bucks later everything is all good.
Allan
***What do I know, I just cause Problems***
*'90 Wrangler*
*4 Banger*
*6" of lift, (4" suspension, 2" body)*
*33" ATs on Outlaw II's*
*Pioneer DEH3500/CD deck*
*1800WATT Amp w/ Custom Box*
*2 - 8" Rockford Fosgate HEs*
*Cobra 18WXSTII w/ 4' Firestik Antenna*
Member of
AllanAlxndr is offline
post #4 of 7 Old 03-03-2002, 08:36 PM Thread Starter
evilpsych
evilpsych's Avatar
500 bucks! screw that.. thik i'll do this.. spend $100 on new calipers, z-rated pads, and new rotors.. unbolt them, put them on, and then bleed the brakes with new fluid.. i figure the previous owners never did a damn thing about rebuilding the calipers or bleeding the old grimy fluid..
A
post #5 of 7 Old 03-04-2002, 03:28 PM
AllanAlxndr
Yeah, that is what I figured too...
Allan
*'90 Wrangler*
*4 Banger*
Member of
post #6 of 7 Old 03-04-2002, 04:27 PM Thread Starter
evilpsych
evilpsych's Avatar
what. you screwed up your own brake job?
A
post #7 of 7 Old 03-04-2002, 04:33 PM
AllanAlxndr
No I took mine in to have it all check out because of the multiple owners and while they were at it I had them do the brakes at the same time.
Allan
*'90 Wrangler*
*4 Banger*
Member of
Knocking: front brakes, rear brakes, drive shaft(?) Ujoints Or Drums? Help? VanBCguy TJ Wrangler Technical Forum 14 01-31-2013 07:34 AM
Replace Rear D44 Drum Brakes with Newer Factory D44 Disc Brakes? NIB-98TJ TJ Wrangler Technical Forum 18 12-30-2009 07:55 PM
95 Front brakes are dragging rear brakes lock up instantly 72RatCamaro YJ Wrangler Technical Forum 2 03-18-2009 06:25 AM
Converting rear drum brakes to disc brakes Urb4nTr0ll YJ Wrangler Technical Forum 4 05-15-2008 06:16 PM
Brakes brakes brakes....Whos got good brakes? Tacoma750 TJ Wrangler Technical Forum 20 12-17-2006 09:15 AM
