BRAKES AGAIN, PLEASE HELP!! - JeepForum.com
post #1 of 2 Old 02-16-2002, 08:55 PM Thread Starter
Jeep Named Thor
How do I get the calalper piston to retact and get it to go back out? I can't even fit the new pads on let alone the new rotor!
1994 Jeep Wrangler YJ
2" body lift
2" shackle lift
31" BF Goodrich All Terrains
Affectionately named THOR
Jeep Named Thor is offline
post #2 of 2 Old 02-16-2002, 09:30 PM
iamthemellowman
All you have to worry about is getting it to retract.. once you're done it'll take a few pumps or more to push the piston out.
To get it back in, the universal method is to get something like a large c-clamp so that you could apply compression on the piston... then you need to crack the bleeder valve...
If that doesn't work,
On my VW i had rear discs, those pistons needed to be screwed back in.. they had an allen/torx/elongated opening to allow fitment of a tool to turn the piston(look for that).. also need to crack bleeder on that as well. But i'm pretty sure the twist action was only necessary since it had an e-brake function inside.
Alright, just got a fresh look at the haynes manual.. on 90+ models it suggest putting the caliper on the disc (without pads) and using a screwdriver through the inspection hole to leverage the piston in... how retarded is that...
i guess on pre 90 a c-clamp can work, and they also show a picture of doing this while the caliper is on the disc.. i usually try to do this off the disc.. I'm unsure if the caliper is bolted down at any of these steps...
gah i need a real manual.
'92 YJ, 4.0L, rs5000, bds 2", 30" for now.
iamthemellowman is offline
Knocking: front brakes, rear brakes, drive shaft(?) Ujoints Or Drums? Help? VanBCguy TJ Wrangler Technical Forum 14 01-31-2013 07:34 AM
Replace Rear D44 Drum Brakes with Newer Factory D44 Disc Brakes? NIB-98TJ TJ Wrangler Technical Forum 18 12-30-2009 07:55 PM
95 Front brakes are dragging rear brakes lock up instantly 72RatCamaro YJ Wrangler Technical Forum 2 03-18-2009 06:25 AM
Converting rear drum brakes to disc brakes Urb4nTr0ll YJ Wrangler Technical Forum 4 05-15-2008 06:16 PM
Brakes brakes brakes....Whos got good brakes? Tacoma750 TJ Wrangler Technical Forum 20 12-17-2006 09:15 AM
