Brakes - JeepForum.com
post #1 of 12 Old 09-05-2011, 06:45 PM Thread Starter
murilstone
1987 YJ Wrangler
Brakes
So my brakes are not good.... i replaced almost the entire system accept the rear drums them self...did "rebuild them" and turned the drums and new shoes. i replaced the rear brake lines but did not for the front (didnt seem to need it).
replaced the calipers on both sides, the power booster, and the master cylinder.
so here is the issue...there is no brakes...nothing...no petal at all
i have returned the master cylinder 4 times...literally...no petal. i have been through 30$ in brake fluid bleeding the life out of this thing.
if i remove the vacuum the pedal does stiffen so im fairly sure the booster is good.
i am at a loss... brakes are supposed to be easy
any thoughts ?
murilstone is offline
post #2 of 12 Old 09-05-2011, 06:50 PM
Raloma
Dont buy a rebuilt master-cylinder, most of them are junk. Spend the extra money and buy new. You won't have any more problems.
Raloma is offline
post #3 of 12 Old 09-05-2011, 08:51 PM
Old4X
1990 CJ7
Did you bench bleed the master(s) first?
You have to do this else you will never get your brakes to work.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #4 of 12 Old 09-05-2011, 09:08 PM
Nickabis
Heres a silly question, did you start by bleeding the brake furthest away from the master cylinder? Just a thought
Nickabis is offline
post #5 of 12 Old 09-06-2011, 06:07 AM
tdewit
Did you adjust the rear brakes (special tool or screw driver) until the shoes are tight against the drums, then a 1/4 turn back before bleeding? Without doing that, you'll never have brakes as the slaves will not push the shoe all the way to the drum.
tdewit is offline
post #6 of 12 Old 09-06-2011, 07:20 AM Thread Starter
murilstone
1987 YJ Wrangler
Not at first, after the second one (master cylinder) i started doing things "by the book" including starting from the furthest brake and moving to each closer one.
i personally had never done drum brakes before so when i did them i called my Uncle and he did adjust them. I assume he did that correctly...they were tight on the drum when i put them back together.
i suppose my next step is to return the rebuilt master cylinder to the store i got it from and head off to NAPA after work and get a brand spanking new one in stead of a rebuilt one....
post #7 of 12 Old 09-06-2011, 07:41 AM
davsyjdd
I made the mistake of replacing the calipers on my sandrail once and I mixed the calipers up and put them on the wrong side. The bleeder has to be at the top of the caliper or you will never get the air out. If they are on the wrong side the bleeder will be at the bottom.
davsyjdd is offline
post #8 of 12 Old 09-06-2011, 07:46 AM
tdewit
Clearly not the problem then.
My rebuild from NAPA was 100%, no problem at all.
Have you checked the combination proportioning valve for proper operation and no line blocks?
I left a link for the FSM, check the BRAKE_S2 section.
https://www.yousendit.com/download/M...ckk3bUJjR0E9PQ
tdewit is offline
post #9 of 12 Old 09-06-2011, 08:54 AM
4.7stroker
Make sure that the front caliper bleed nipples are at the highest point. It is easy to get them on the wrong side.
Gravity bleed the brakes, some people have problems with the two man(or girl) system.
To gravity bleed all you do is, starting from the furthest brake crack the nipple and let it drip until there are no more bubbles(helps if you have a clear plastic hose pushed onto the nipple) then move onto the next. total time less than an hour and you will use less than a pint of fluid.
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
post #10 of 12 Old 09-06-2011, 11:58 AM Thread Starter
murilstone
1987 YJ Wrangler
Dwayne,
I think you might have the winner!!!
the bleeder valve is below the brake lines...that only makes sense
post #11 of 12 Old 09-06-2011, 12:04 PM
clush
I was gonna say check the front calipers, I have heard more than one person do that.
clush is offline
post #12 of 12 Old 09-06-2011, 01:41 PM
Bad_Dog
Originally Posted by murilstone View Post
Dwayne,
Been there, done that. I was replacing both of my front calipers and ended up installing them with the nipple down. Couldn't figure it out. Only after a post on here did someone remind me that air sorta goes UP and now down. When you're frustrated, sometimes the most-obvious thing doesn't stand out. It makes sense why bleeding them, pointing down, didn't help!
OlllllO 2013 Wrangler Sahara Unlimited
[]lllll[] 1991 Wrangler Renegade, 4.0L Auto (Retired 2013)
Bad_Dog is offline
Knocking: front brakes, rear brakes, drive shaft(?) Ujoints Or Drums? Help? VanBCguy TJ Wrangler Technical Forum 14 01-31-2013 07:34 AM
Brake upgrade for those running D44/Chevy brakes(waggy brakes included) RockRodHooligan TJ Wrangler Technical Forum 29 11-09-2012 05:23 AM
Replace Rear D44 Drum Brakes with Newer Factory D44 Disc Brakes? NIB-98TJ TJ Wrangler Technical Forum 18 12-30-2009 07:55 PM
95 Front brakes are dragging rear brakes lock up instantly 72RatCamaro YJ Wrangler Technical Forum 2 03-18-2009 06:25 AM
Brakes brakes brakes....Whos got good brakes? Tacoma750 TJ Wrangler Technical Forum 20 12-17-2006 09:15 AM
