Brake system replacement tips? - JeepForum.com
post #1 of 8 Old 08-09-2013, 11:03 AM Thread Starter
scraper
I'm about to do a complete brake system reinstall on my 95 YJ. After it sat in a barn for 5 years I finally got it running again and now I want to replace the brake system, mostly because it's in really bad shape and I don't want it to go out when I need it. So I am replacing:
1. The power booster. (The original was in bad shape)
2. Master Cylinder. (I broke this getting the power booster out)
3. all lines and hoses up to the brakes themselves. (I went with a standard steel coil for the lines, mostly because I'm already WAY over budget. ie keep the wife happy).
I'm not gonna worry about extended brake lines at this point because I'm happy with my 2.5" lift and if I need more I will just get extenders.
So the real question is, does anyone have any pointers or suggestions before I start the reinstall on this project. I have never actually done a brake system reinstall like this before.
scraper is offline
post #2 of 8 Old 08-09-2013, 11:06 AM
Reno72
On the booster measure the length of the pin going into M/C off the old booster, then adjust the tip on the new booster to match. This will save you from having to remove and adjust the new booster.
Reno72 is offline
post #3 of 8 Old 08-09-2013, 11:12 AM Thread Starter
scraper
I never would have thought of that. Thanks.
scraper is offline
post #4 of 8 Old 08-09-2013, 11:15 AM
jbolty
jbolty's Avatar
replace the calipers and wheel cylinders as well; it will only add about $40 to the job.
Personally I would not bother with a coil of brake line and having to cut and flare all the sections. You can do the entire job with pre flared tube sections. They come in many different lengths and make the entire process a lot easier. Flaring brake lines is not hard, but it is a skill that takes practice to do well.
jbolty is offline
post #5 of 8 Old 08-09-2013, 11:25 AM Thread Starter
scraper
I just thought of a question.
The line going from the cylinder to the little distribution junction (I have no idea what this part is called, it sits under the cylinder and the brake lines run from it) are coiled. Is this necessary or can I just run straight lines? My thinking is that Chrysler did this so it would have some give, but it's probably not necessary.
scraper is offline
post #6 of 8 Old 08-09-2013, 11:39 AM
jbolty
jbolty's Avatar
That's the proportioning valve. To my knowledge the coils are just there for vibration/movement. I have seen numerous vehicles with straight line there or stainless braided.
jbolty is offline
post #7 of 8 Old 08-09-2013, 11:56 AM
GrantYJ
X2!!!
I've had my Jeep a long time, several years ago I started doing the following.
Whenever anything in the brake system needs replaced, I pull everything but the booster, proportioning valve, and the lines. The MC, Calipers, cylinders, pads, and shoes all come off. On my Jeep, all of these have a lifetime warranty so all it costs me in the end is new fluid. All this can be done easily in an afternoon and it'll stop like it did when it was new afterwards.
(I should probably feel bad for bringing back parts that aren't shot, but for what I had to pay for my first MC, I don't.)
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.” ― Robert M. Pirsig, Zen And The Art Of Motorcycle Maintenance: An Inquiry Into Values
GrantYJ is offline
post #8 of 8 Old 08-09-2013, 02:06 PM
metalhead
2011 WK
Just go to the dealership and get the proper lines for your model. They are not that expensive. They are all pre bent and flared. I am a mechanic and flaring brake lines takes some practice. I have not done it myself but guys I work with have and if its not done right it will leak. I got the line that runs from the proportioning valve to the rear for 34 bucks and the line that goes from the valve to the left front wheel for like 10 bucks from the dealer.
metalhead is offline
