Brake System Problem - JeepForum.com
post #1 of 4 Old 04-23-2012, 06:02 AM Thread Starter
DRLongo
So I the brake line to the rear drums from the proportioning valve on my '92 blew last week. Installed all new SS lines and bled the system starting with rear passenger, driver passenger, front passenger, ...and here is where I ran in to problems. I got nothing coming out out of the bleed valve. I narrowed my problem down to the shuttle in the proportioning valve. It seems that as long as I press slow and steady on the break pedal, the front passenger caliper gets pressure. Soon as I press non the brake with normal foot pressure it is like the shuttle jams against the valve body and prevents any pressure getting to the FP caliper. Did I forget something when bleeding the lines or is it time for a new proportioning valve?
DRLongo is offline
post #2 of 4 Old 04-29-2012, 06:09 PM Thread Starter
DRLongo
Nevermind, for anyone else having this problem i pulled apart the shuttle valve section of the proportioning valve after removing the switch sensor and reset the shuttle valve in its proper position. Problem seems solved.
DRLongo is offline
post #3 of 4 Old 04-29-2012, 06:51 PM
jbolty
jbolty's Avatar
exactly the correct fix and thanks for posting back. One function of the proportioning valve is to direct the braking to the remaining circuit if one side fails. It's pretty simple to fix, but a big mess and a lot of bleed after.
You should probably replace teh rest of the hard lines before it happens again; they are all the same age.
jbolty is offline
post #4 of 4 Old 04-29-2012, 07:17 PM Thread Starter
DRLongo
Replaced all the hard lines with ss after the rear line blew.
DRLongo is offline
brake bleeding , brake proportioning valve
Brake system bleeding problem. VamosJEEP YJ Wrangler Technical Forum 13 09-02-2009 06:57 AM
Air getting in brake system MooseMarine YJ Wrangler Technical Forum 8 04-01-2009 11:53 AM
abs brake system hilton00 TJ Wrangler Technical Forum 5 01-07-2009 04:39 AM
Brake system sqeek? Tazzrider TJ Wrangler Technical Forum 1 04-21-2007 07:08 AM
hiss from brake system? ElvisV04290 YJ Wrangler Technical Forum 2 10-22-2006 11:34 PM
