Brake System Failing - JeepForum.com
post #1 of 6 Old 02-16-2013, 06:17 PM Thread Starter
0verkillYJ
So I did some heavy mudding today and after leaving the trails and driving around 10-15 miles my brakes started working on and off. If I pump them I get pressure back, but then the petal will go back to the floor next time I press them to stop. I couldn't find a leak in the front or the rear. I checked my master cylinder and the front was fine, but the rear only had about 10% left in it. What is weird though is I have driven without rear brakes before and know the difference between just the rear failing and my entire system acting up. Does anyone know what this could be? I couldn't figure it out at all and ended up having to park it until tomorrow morning in a friends backyard about 5 miles away from me.
0verkillYJ is offline
post #2 of 6 Old 02-16-2013, 08:01 PM
TSEJEEPERS
Sounds like leaking wheel cylinders to me.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #3 of 6 Old 02-16-2013, 08:39 PM Thread Starter
0verkillYJ
I got calipers all around. Also, the front and rear are separate, so I would still have half my brakes but I do not. When I pump them I get pressure back, but if i dont use my brakes for 5 sec or more I lose pressure again.
post #4 of 6 Old 02-16-2013, 08:43 PM
Mark05059
sounds like your master is junk...
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #5 of 6 Old 02-16-2013, 09:00 PM
kjg26
kjg26's Avatar
Or the booster is on its way out. I've got factory master/booster/ prop valve from a 93 you can have for the price of shipping
Black 1993 YJ 4.0, 5 Speed
Slowly but surely getting better and better. Trailer build soon!!
kjg26 is offline
post #6 of 6 Old 02-17-2013, 08:53 AM Thread Starter
0verkillYJ
I am going to do some troubkeshhoting today and might take you up on that.
95 YJ, 2.5 AX15 conversion, 4.0 TB, SOA +1.5", 33" DC Crusher Tires, 8.8 Rear w/welded tubes + LSD, Spartan Locker HP30 Front w/solid axle swap, Rocky Road OTT kit, JKS Disconnects, AA SYE, Teraflex Shock Bar in Rear, 1/2" Boomerang Shackles, RE Add a Leafs, Homebrew Traction Bar, Monstalined in&out, LED Tail lights, 1700 Watt Stereo
