brake switch question - JeepForum.com
post #1 of 11 Old 07-08-2010, 12:46 PM Thread Starter
cwbymt1973
Anyone do a 4.3 swap and put a auto in and have to run the 4 pin brake switch to lock and unlock the convertor. if so can you tell or send me a pic of how you mounted to the brake pedal or how you did your setup. i used a painless wiring harness in mine.
Thanks,
Matt
cwbymt1973 is offline
post #2 of 11 Old 07-08-2010, 03:07 PM
5.7YJ
5.7YJ's Avatar
1987 YJ Wrangler
I couldn't find a brake light switch that would work without the extra work of adding a bracket. What I did was use a relay activated by the stock brake light switch. It has been a while since I did it and will have to see how I wired it. I have the diagram from the back page of my Painless installation book and have notes telling me what color wires I used to make it work but I need to get under the dash and look before I tell you something wrong. I will take a look, scan the page and get back with you.
5.7YJ is offline
post #3 of 11 Old 07-08-2010, 06:37 PM Thread Starter
cwbymt1973
that would be awesome thanks for the help
post #4 of 11 Old 07-09-2010, 09:47 AM
5.7YJ
5.7YJ's Avatar
1987 YJ Wrangler
Here is the diagram of how mine is hooked up. I hope this will help.
5.7YJ is offline
post #5 of 11 Old 07-09-2010, 10:08 AM Thread Starter
cwbymt1973
And you used the one already on the jeep right
post #6 of 11 Old 07-09-2010, 02:56 PM Thread Starter
cwbymt1973
And wiring this way will lock and unlock my torque converter.
Matt
post #7 of 11 Old 07-09-2010, 08:13 PM
5.7YJ
5.7YJ's Avatar
1987 YJ Wrangler
It will unlock the convertor when you step on the brakes and the speed sensor should keep it unlocked until 45 miles per hour or so. This is how I understood it, the diagram used a pressure type brake switch but I saw no difference in using my stock brake light switch.
5.7YJ is offline
post #8 of 11 Old 07-09-2010, 09:20 PM Thread Starter
cwbymt1973
great thanks i am all over that to see what happens.
Matt
post #9 of 11 Old 07-09-2010, 10:37 PM Thread Starter
cwbymt1973
ok so wired like the pic last question how do you know when its locked and unlocked?
post #10 of 11 Old 07-12-2010, 09:31 AM
5.7YJ
5.7YJ's Avatar
1987 YJ Wrangler
If it was locked up at idle (in gear and on the brakes) it would push the Jeep forward and lug it down, and when your above 45 (if using a non-adjustable speed sensor) hit the brakes while on the gas and your RPM's will come up a few hundred.
5.7YJ is offline
post #11 of 11 Old 07-12-2010, 07:41 PM Thread Starter
cwbymt1973
yea thats what it did thanks again for your help
Matt
Brake Switch lyoncc YJ Wrangler Technical Forum 1 03-06-2010 08:52 PM
brake switch help please Codyf12 TJ Wrangler Technical Forum 1 06-05-2009 01:44 PM
brake switch fix wegotj TJ Wrangler Technical Forum 2 08-19-2007 08:32 PM
Brake Switch Bachman TJ Wrangler Technical Forum 5 07-29-2007 03:39 PM
Brake light switch....... GzrGlide TJ Wrangler Technical Forum 4 11-01-2005 07:41 PM
