Brake suggestions - JeepForum.com
post #1 of 16 Old 04-30-2013, 04:27 PM Thread Starter
maxthegi
Brake suggestions
I wanted to upgrade my brakes. I am not happy with the stock system. I am looking to do calipers, pads, rotors. Any suggestions on sets that you all have used? My jeep is my DD and the traffic here can go from moving to dead stop pretty quickly, plus the pedestrians and bicycles are everywhere. Open to y'alls suggestions. Thanks!
maxthegi is offline
post #2 of 16 Old 04-30-2013, 04:33 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
4 wheel disk is the way to go.
Luck Favours The Prepared
Anticanman is offline
post #3 of 16 Old 04-30-2013, 04:45 PM Thread Starter
maxthegi
Not doing that till I get back to the states and can change the rear out for the 8.8. For right not I just want the front system swapped out.
maxthegi is offline
post #4 of 16 Old 04-30-2013, 05:34 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
There are all sorts of variations of stopping power from parts counter elite brakes to a wj dual piston caliper to a '95 dual diaphragm booster and a napa m2008 (e-350 master cylinder)
How much more braking power do you need?
post #5 of 16 Old 04-30-2013, 05:56 PM
4.7stroker
Install a 95 dual diaphram booster. The other stuff works fine it just needs higher pressure.
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
post #6 of 16 Old 04-30-2013, 06:36 PM
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
95 boosters are hard to find. TJ boosters are everywhere. Just needs a little fab work. There are a few write ups on it. If you need help with it I can walk you through it. By far the best thing I have ever done to improve drivability of my jeep. I can easily lock up my 33's
YJ 350TPI NV4500 HPD60 14BFF ARB Chromo's
March 2017 YJOTM
87TPIYJ is offline
post #7 of 16 Old 04-30-2013, 06:43 PM
jbolty
jbolty's Avatar
For the most simple upgrade change to Black Magic or EBC pads. Very noticeable difference.
jbolty is offline
post #8 of 16 Old 04-30-2013, 07:36 PM
4.7stroker
Na not really only took me 2 mins.
http://www.ebay.com/itm/A1-Cardone-R...28476a&vxp=mtr
[url]
[url]
post #9 of 16 Old 04-30-2013, 07:45 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
I found one on here. It should be en route by tomorrow.
post #10 of 16 Old 04-30-2013, 07:56 PM
jbolty
jbolty's Avatar
If you get a Cardone booster plan on going through at least 2 or 3 before you find one that works.
jbolty is offline
post #11 of 16 Old 04-30-2013, 08:06 PM
4.7stroker
The reman distributor I got was flawless.
Dw
[url]
[url]
post #12 of 16 Old 04-30-2013, 08:27 PM
5.7YJ
5.7YJ's Avatar
1987 YJ Wrangler
Mine has been on for about a year and a half and have had zero issues with it. I have never had any issues with A1 Cardone parts.
87 YJ, TPI 5.7, 700R4, NP231, BDS 3.5" lift, 1" front & 5/8" rear boomerang shackles, Rubicon Dana 44 rear axle, 33" Goodyear Duratracs
My brake boster/master cylinder upgrade:
5.7YJ is offline
post #13 of 16 Old 04-30-2013, 08:49 PM
jbolty
jbolty's Avatar
You are all lucky. I have first hand experience with three bad boosters in a row on my jeep, and two others with two each.
jbolty is offline
post #14 of 16 Old 04-30-2013, 08:53 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
I found mine in the classifieds from a parted out Yj. Sorry if I misled with my ill timed post.
post #15 of 16 Old 05-01-2013, 02:32 AM Thread Starter
maxthegi
I guess I should have clarified. Fab work is probably out of the question. I live in Japan on a tiny military base. Don't have access to that stuff. Bolt on replacements. Thanks for all the comments!
maxthegi is offline
