Brake shoe and cylinder replacement - JeepForum.com
post #1 of 17 Old 05-12-2011, 05:10 PM Thread Starter
mbarrett1102
2010 JK Wrangler
I have searched all over and not just on this site and can't seem to find a good write up on replacing brake shoes and the brake cylinders (in the rear of course)...the Haynes manual I have has the black and white photos that are killing me...just don't want to mess this up and end up with an unsafe jeep...I have new shoes and cylinders as well as the brake spring remover...any tips would be greatly appreciated
mbarrett1102 is offline
post #2 of 17 Old 05-12-2011, 05:18 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
http://www.lunghd.com/Tech_Articles/...ke_Service.htm
Max
Sent from my HTC Incredible Droid
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #3 of 17 Old 05-12-2011, 05:22 PM
4.7stroker
I just jack up the rear remove both wheels and drums then do one side at a time using the other side as a reference.
PS chock both front wheels to avoid a trip to the ER.
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
post #4 of 17 Old 05-12-2011, 05:30 PM Thread Starter
mbarrett1102
2010 JK Wrangler
Have a shop I can use the lift for 5 bucks an hour so not worried about that part...thanks for the write up max! Recommend doing the drums while I'm there? Don't know the last time they were replaced or turned, they look rusty on the outside though
post #5 of 17 Old 05-12-2011, 05:39 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
I would measure their diameter to see if there is still enough material remaining before turning them. I would only turn them if there's enough material AND you have access to a brake lathe to do it yourself. Lately I have found machine shop pricing to be online with the cost of new drums. I have access to a lathe, so I usually just clean them up.
Max
Mean Max is offline
post #6 of 17 Old 05-12-2011, 05:46 PM
4.7stroker
I just break the glaze using 80 grit emery as long as there is no major scars.
But as mentioned if they are in need of lathe work it is just better to buy new.
Dwayne
[url]
[url]
post #7 of 17 Old 05-12-2011, 06:24 PM Thread Starter
mbarrett1102
2010 JK Wrangler
well for 70 bucks i can get new drums from advance...going to shop around more, but might be worth it so I don't have to worry about doing this job again for a while...looks like there are a lot of parts that can be lost in the shuffle if you arent careful. thanks for all of the help!
post #8 of 17 Old 05-12-2011, 06:32 PM
4.7stroker
Ebay has good deals on parts also, they are worth a look.
A tip on bleeding the brakes,
Put cling film on the master cyl and reinstall the lid before you start your brake work, this will help keep the fluid loss to a minimum.
When you do bleed your brakes remove the cling film suck out as much fluid as you can with a turkey baster and refill with fresh new fluid. Crack one bleed nipple open and just wait, in short order a steady drip of fluid will spring forth just wait for it to be clean and close the nipple then move on to the other cylinder and repeat.
I would also do the fronts till clean fluid drips.
Gravity bleeding works very well does not entrain air into the fluid and is a one man operation.
Dwayne
[url]
[url]
post #9 of 17 Old 05-12-2011, 06:47 PM Thread Starter
mbarrett1102
2010 JK Wrangler
Thanks Dwayne!! I did the power booster 2 weekends ago, and did the bleeding with the one man brake booster so luckily the fluid is all brand new, but I will use that cling wrap trick...sounds much easier. Now just to get the stripped bleeder valve off of the right front brake...even vice grips and pb blaster wouldn't free her. Any suggestions?
post #10 of 17 Old 05-12-2011, 07:11 PM
4.7stroker
Calipers are cheap, don't waste your time if it is stuck just toss in a new one, hell make it a party and change both of them.
Easy to say when it isn't my money.
Dwayne
[url]
[url]
post #11 of 17 Old 05-12-2011, 07:29 PM
MJMPC
Do yourself a favor and get a good set of line wrenches.
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #12 of 17 Old 05-12-2011, 07:29 PM Thread Starter
mbarrett1102
2010 JK Wrangler
Well since I'm in the military it kind of is your money....mind a few extra bucks in taxes for my jeep project?
Thanks for the tips!!
Noticed you're from Rio Rancho, lived in Albuquerque for 3 years and my mom is moving back that way...any suggestions on nice neighborhoods near Kirtland AFB? Maybe we can go wheeling sometime when I visit, if my YJ can make it that far
post #13 of 17 Old 05-12-2011, 07:31 PM Thread Starter
mbarrett1102
2010 JK Wrangler
MJMPC...So you mean my strategy of buying tools one at a time as I do the job isn't a good call? hahaha well since the jeep has made me a top stockholder in Advance Auto Parts, I'll look and see what deals and options they have. Thanks!
post #14 of 17 Old 05-12-2011, 07:44 PM
MJMPC
Everytime I work on the jeep I buy a new tool drives the old lady crazy.
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #15 of 17 Old 05-12-2011, 07:46 PM Thread Starter
mbarrett1102
2010 JK Wrangler
I guess I am the old lady in my situation, but it doesn't drive me crazy...guess I win some cool points on that one hahaha
Emergency brake shoe install yfzandy JK Wrangler Technical Forum 9 04-25-2011 07:06 PM
E brake shoe adjustment question. Ezalycasaid TJ Wrangler Technical Forum 5 02-19-2011 01:53 AM
8.8 Parking Brake Shoe - Problem linusb YJ Wrangler Technical Forum 7 10-10-2010 12:30 PM
Slave Cylinder Replacement bryris YJ Wrangler Technical Forum 16 06-01-2008 05:30 PM
Brake Pads & Shoe recommendations? BNovak TJ Wrangler Technical Forum 2 07-27-2004 05:05 AM
