brake question - JeepForum.com
post #1 of 4 Old 12-06-2006, 08:19 AM Thread Starter
jimaug87
brake question
My brake have been feeling spongy and soft so i checked out my master cylinder to check the fluid, and the front smaller compartment is empty. im going to fill it up today when i swing by autozone for some fluid. but what are the 2 compartments for? why is the front one empty? could there be a leak and have one empty and have the other still work? my brake have been progressivly getting worse, faster then pads wear. Thanks, you guys are always a help.
jimaug87 is offline
post #2 of 4 Old 12-06-2006, 08:50 AM
sequel
So the smaller compartment is fluid for the rear brakes. They have two separate chambers so it it isolates the front from the rear providing some redundancy in case of failure.
So if you have no fluid in the small chamber, it means you probably have a leak. Check both wheel cylinders in the rear for leaks. You may have to replace them and then bleed the brakes once you fill the fluid.
1992 Black YJ, 4L I6, 8.8 Rear
3.5" BDS, 5/8" MORE Shackles,
DT-3000s, 16x8 Bajas,
285/75R16 Dunlop Mud Rovers
sequel is offline
post #3 of 4 Old 12-06-2006, 09:56 AM
kloppk
You will definitely have to bleed the rear brakes.
Also the leak may be in the line that runs from the proportioning valve
to the rear axle or a line on the rear axle could also be leaking.
kloppk is offline
post #4 of 4 Old 12-06-2006, 10:00 AM Thread Starter
jimaug87
redundancy in case of failures, like mine. good going jeep engineers, so right now im just stopping with the front brakes huh? ok. so i just trace the line from the smaller compartmenmt to the back of the jeep until i find something wet. cool. thanks guys. i think its time for new pads anyway.
jimaug87 is offline
Brake Question snakester14 TJ Wrangler Technical Forum 7 01-06-2008 02:29 PM
YJ 8.8 e-brake question three YJ Wrangler Technical Forum 7 03-29-2007 02:00 PM
Brake Chime w/Emerg. Brake Question jtstj TJ Wrangler Technical Forum 10 02-24-2006 06:23 AM
Brake line and E-brake Question vdubstreets YJ Wrangler Technical Forum 43 12-28-2005 07:02 AM
8.8 Brake question - connecting to the exisiting hard brake line? BNovak TJ Wrangler Technical Forum 2 06-10-2005 02:25 PM
