Brake Question - JeepForum.com
post #1 of 7 Old 01-30-2012, 08:22 AM Thread Starter
boxcar119
Brake Question
Brake pedal had been getting soft. Now I have to pump twice to build up
pressure. If I just pump once pedal goes to the floor and e-brake light
comes on. If I pump twice no light.
Shoes and pads in decent shape
Do you think it's the MC or the booster or both ?
any way to test ?
thanks
'93 YJ 6cly Man
boxcar119 is offline
post #2 of 7 Old 01-30-2012, 08:31 AM
scubamc
Have you checked your brake fluid? Have your tried bleeding all your lines?
scubamc is offline
post #3 of 7 Old 01-30-2012, 09:18 AM
DLWRUBI
Most likely the MC is gone..
DLWRUBI is offline
post #4 of 7 Old 01-30-2012, 11:12 AM
69moparman
any way to test ?
thanks
'93 YJ 6cly Man
First you should check your brake fluid as stated earlier. If that's at a good level, try sitting in the seat and push the brake pedal and hold medium pressure on it. If the pedal fades to the floor, one of two things could be wrong. The plunger seal inside the master cylinder is shot or you have a fluid leak somewhere in the brake system. Check all your hard and soft lines for leakage, also remove your rear drums and look for wet areas around the wheel cylinders. If the leak is bad enough, you'll see fluid running down the inside of the tire. If there's no apparent leak, it's probably time to replace the master cylinder.
69moparman is offline
post #5 of 7 Old 02-20-2012, 09:03 AM
Shoelessboi
Any news on this? I'm going thru the same thing. It started off by pumping brakes.. then its now i have no pressure while its running. I bled all 4 lines.
Originally Posted by dillonjm View Post
:The fact you even asked this question makes me want to punch myself in the face.
1991 Jeep Yj. 4cyl. 33x13.50x15 TSL Thornbirds, Super Wader Snorkel, 4" Rough Country Suspension Lift, Uniden Pro520xl Cb, 1000W Amp, 12" Rockford Fosgate P2 Sub.
Shoelessboi is offline
post #6 of 7 Old 02-20-2012, 09:07 AM
nembudonna
Get a new master,
nembudonna is offline
post #7 of 7 Old 02-21-2012, 06:55 AM
Shoelessboi
Originally Posted by nembudonna
Get a new master,
Im ordering one today.
Brake question, brake light on SayBye YJ Wrangler Technical Forum 3 06-26-2011 11:08 AM
8.8 E-brake question olesahara YJ Wrangler Technical Forum 2 09-10-2008 02:06 PM
Brake Chime w/Emerg. Brake Question jtstj TJ Wrangler Technical Forum 10 02-24-2006 06:23 AM
Brake line and E-brake Question vdubstreets YJ Wrangler Technical Forum 43 12-28-2005 07:02 AM
8.8 Brake question - connecting to the exisiting hard brake line? BNovak TJ Wrangler Technical Forum 2 06-10-2005 02:25 PM
