Brake Proportioning valve help - JeepForum.com
post #1 of 5 Old 03-15-2012, 05:06 PM Thread Starter
Rockabilly
I think my brake lines may be connected to the wrong outlets of the valve. Could someone post a pic of their prop. valve and label the outlets as to which two arOe front and which one is rear? Or I guess you could just start at the outlet closest to the firewall and state which goes where like that. TIA
Wheel it! Break it! Repair it! Repeat!
Rockabilly is offline
post #2 of 5 Old 03-15-2012, 05:45 PM
timatoe
timatoe's Avatar
I don't have a pic handy, but the lines on the master cylinder should be.... front is the one closest to the booster.... and rear is obvioulsy then toward the front..... those lines in turn connect to the proportioning valve, the line for the front connects to the side with two outlets and the rear to the one..... Let me get pic...
OK, so I'm in the middle of a project and just swapped a TJ booster, master, and prop into mine, so the pic is different than yours looks but the lines are the same.
Please excuse my super fast labeling.....
timatoe is offline
post #3 of 5 Old 03-15-2012, 07:05 PM Thread Starter
Rockabilly
Thanks! That is exactly what I needed.
post #4 of 5 Old 06-30-2013, 06:55 AM
jmconti
Me too! almost impossible to find. Thanks!!
jmconti is offline
post #5 of 5 Old 06-30-2013, 07:22 AM
TSEJEEPERS
Nevermind.
If you look at the proportioning valve there are two lines going out for the front brakes and only one for the back.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
Brake proportioning valve for 03+ TJ fish4life TJ Wrangler Technical Forum 33 08-13-2010 08:23 PM
brake proportioning valve With 8.8? jeepwrangler97 TJ Wrangler Technical Forum 17 12-11-2009 12:43 AM
brake proportioning valve Dantheshan YJ Wrangler Technical Forum 17 06-02-2009 08:12 PM
D35 to D44 Brake proportioning valve Jeepersinco TJ Wrangler Technical Forum 2 07-08-2005 07:32 PM
brake proportioning valve BudgetWheeler YJ Wrangler Technical Forum 5 06-17-2005 09:54 AM
