brake problems - JeepForum.com
post #1 of 8 Old 08-16-2013, 05:33 AM Thread Starter
cuate01221
brake problems
I noticed yesterday that my brakes felt a little low, then it went straight to the floor so I just figured one of my lines blew. I pulled over to check it out and not a single drop of fluid on the floor? Opened up the resevouir and it was full too... I'm starting to think its the master cylinder just going bad. I did notice that if I keep my foot on the brake pedal it will hold pressure but as soon as I let off even the slightest and push back in, it goes lower and lower until I have no brakes at all, then if I let go and wait a minute they work as long as i hold it steady and don't let off. Any ideas?
EDIT: I just did both front calipers and bled the system out correctly.
cuate01221 is offline
post #2 of 8 Old 08-16-2013, 09:02 AM
Que89YJ
Did you just replace both calipers? The common thing is to put them in upside down. Is your bleed screw on the top or bottom? If it is on the bottom of the caliper you need to flip them.
Que89YJ is offline
post #3 of 8 Old 08-16-2013, 09:40 AM
EABiker
It does sound like the master is going bad; you can usually get OK pressure by quickly applying the brakes, but lose it with your foot sitting on the pedal. Time for a new one! Don't forget to bench bleed it before hooking up the lines.
EABiker is offline
post #4 of 8 Old 08-16-2013, 11:43 AM
pasinbuy
Ditto, common mistake and I did it myself. Look at your calipers. The bleeder must be on the top. The calipers have a left and right side.
pasinbuy is offline
post #5 of 8 Old 08-16-2013, 12:12 PM
Rproject
1987 YJ Wrangler
X3. Ask me how I know.
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #6 of 8 Old 08-16-2013, 04:36 PM Thread Starter
cuate01221
Both are on top, I think I know what's wrong with it, called up my dad and told him what was happening and he told me that he was checking it out and noticed brake fluid was a little low so he filled it with power steering fluid : gonna try bleeding it all out today.
post #7 of 8 Old 08-16-2013, 04:47 PM
Rproject
1987 YJ Wrangler
Oh no!!!! I hope you can save the flexible lines a reservoir. My son's buddy did the same thing. Cost him $400 to get fixed.
1996 White ZJ
Rproject is offline
post #8 of 8 Old 08-16-2013, 07:07 PM Thread Starter
cuate01221
Yeah! Well good thing its gonna be parked for a manual swap Time to start inspecting!
