Brake Pressure Differential Switch Connector - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Brake Pressure Differential Switch Connector
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffstuff Axle Simple Swap Kit!Nitro Gear Packages Now Available at Rockridge 4wd
Unread 08-12-2014, 06:15 PM   #1
dennisonwj
The Brake Pressure Differential Switch Connector I have is damaged. I would like to buy a new one to solder on the end of the wire so I can plug it into the proportioning valve. Anyone know where I can get one?
dennisonwj is offline   Reply With Quote Quick reply to this message
Unread 08-13-2014, 12:53 PM   #2
Que89YJ
cfoffroad.com
Que89YJ is offline   Reply With Quote Quick reply to this message
