Brake Petal Whine - JeepForum.com
post #1 of 3 Old 08-05-2011, 01:05 PM Thread Starter
Hawk37
Brake Petal Whine
I've noticed recently, that after a complete stop the brakes make a high pitch whine while I switch from brake to clutch. The noise relates directly to the up travel of the petal. Is this a sign that my master cylinder is going out? Booster? I checked the reservoirs and the fluid is a little yellow, but its still full. Ideas?
Hawk37 is offline
post #2 of 3 Old 08-05-2011, 04:01 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Sounds like a bad booster. Squeeze the large vacuum line going into the booster with something to clamp it off & attempt to repeat the same scenario again. If there isn't any noise with the vacuum line clamped off, it's a bad booster.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #3 of 3 Old 08-08-2011, 11:53 AM Thread Starter
Hawk37
I'll give that a try. Thanks
Hawk37 is offline
No cluch petal fran87yj YJ Wrangler Technical Forum 3 02-05-2010 12:07 AM
electronic cylinder on clutch petal? fiberguy30 TJ Wrangler Technical Forum 1 03-01-2008 11:33 PM
Too much skinny petal kankan YJ Wrangler Technical Forum 6 07-02-2007 03:32 AM
Whine mcastie89 TJ Wrangler Technical Forum 1 09-20-2005 12:52 PM
Clutch petal on 97 TJ. Plastic clip??? 97TJ2.5 TJ Wrangler Technical Forum 5 02-05-2003 04:19 PM
