brake pedal sticks 94 2.5 near stock - JeepForum.com
post #1 of 4 Old 08-23-2008, 04:51 PM Thread Starter
cost plus
when I press the brake pedal it stops the jeep, but will not lift and release the brake when you lift you foot off the pedal.. I have to lift the pedal manually to release the brake and turn the brake light off. need advise
this is an off road only jeep but it has become a problem when a newby drives it and cannot figure out why it wont go
thanks
cost plus is offline
post #2 of 4 Old 08-24-2008, 02:56 PM Thread Starter
cost plus
Bump to the top.
post #3 of 4 Old 02-25-2009, 05:04 PM
gatkerson
Were you able to find the solution to your problem??
gatkerson is offline
post #4 of 4 Old 02-25-2009, 05:12 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Brake booster is NG. Or you have racked the body and the brake booster rod is bent/jammed.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
Gas pedal sticks, Trans won't shift when cold JEEP97TJ TJ Wrangler Technical Forum 12 06-14-2015 12:14 PM
Clutch pedal sticks dlindberg YJ Wrangler Technical Forum 6 02-05-2009 07:25 AM
Brake Pedal Sticks halfway walkin YJ Wrangler Technical Forum 4 11-29-2008 12:18 PM
gas pedal sticks.....what do I do? fooswinger YJ Wrangler Technical Forum 4 08-01-2007 01:25 AM
brake pedal sticks jeep795 YJ Wrangler Technical Forum 4 06-15-2006 04:03 PM
