Brake pedal stays down, won't come back up - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Brake pedal stays down, won't come back up
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 02-10-2006, 07:54 AM   #1
SAB30
Many of the threads I read started out with, "I did a search but couldn't..."
So...
I did a search but couldn't find anything that would help me trouble shoot why when I press the brake pedal it stays down and won't come back up unless I reach down and grab it. Any suggestions?
It just all of a sudden happened.
The brakes work well and the peddle is firm, just like it should be, but the pedal won't return after it is depressed unless I grab it with my hand and pull it back. The brakes remain activated as long as the pedal is down. When I pull the pedal back up there isn't much resistence, and once back up, the pedal stays up and the the brakes do not drag.
Any suggestions would be greatly appreciated.
Shawn
Oh, by the way it is a stock '92 YJ, 4 cyl. manual transmission
SAB30 is offline   Reply With Quote Quick reply to this message
Unread 02-10-2006, 08:08 AM   #2
naviathan
Your master cylinder is probably gunked up. There's a spring inside the cylinder that pushes the plunger back out. If that spring for some reason gets stuck it won't return. Sounds like time for either a rebuild or a new brake master cylinder.
SOLD - Maybe I can afford this game when I'm old and rich.
naviathan is offline   Reply With Quote Quick reply to this message
Unread 02-10-2006, 08:24 AM   #3
paintguy
I would try gravity bleeding the master through the front two calipers first, adding fluid as it runs out and then do the rear via the wheel cylinders -- this will get new fluid running through the master and maybe it will come back. Worth a try before you drop 60 bucks!
paintguy is offline   Reply With Quote Quick reply to this message
Unread 02-10-2006, 10:46 AM   #4
Vancopbs
Turn the car off, step on the pedal a few times to kill vacuum. Does the pedal return with the car off? Most likely the booster.
To check, start the car again, let it run 30 seconds and turn it off. Wait a minute and remove the plastic check valve the hose connects too. If you don't hear vacuum release it's your booster.
Van
Vanco Power Brake Supply
9738 Atlantic Ave
South Gate, Ca 90280
800-256-6295
323-563-1588
Vancopbs is offline   Reply With Quote Quick reply to this message
Unread 05-29-2010, 11:54 AM   #5
92cherokeelimit
1992 XJ Cherokee
booster? LoL, Is that part of my master cylinder? The same thing is happening to me I was just gonna replace the master cylinder is that what i should do? I dont want to rebuild it really.
92cherokeelimit is offline   Reply With Quote Quick reply to this message
Unread 05-29-2010, 12:00 PM   #6
92cherokeelimit
1992 XJ Cherokee
Mine stays down if the jeeps on or off. I will try pushing ti a few times when its off and see what happens. The plastic check valve on what piece the master cylinder or booster? Where is the booster located. For the record i use my other foot to bring the pedal back up while im driving.. The further i press em down the worse it sticks. The pads look ok i hear the abs go of for no reason at all sometimes i think. I plan to redo the front brakes entirely but id like to get rid of this problem as the first step. I will do the caliper pads and rotors but if this just the master ill do that first. Anyone know for sure?
Unread 05-29-2010, 03:08 PM   #7
vector6
vector6 is offline   Reply With Quote Quick reply to this message
Unread 05-29-2010, 03:35 PM   #8
MJMPC
Does the pedal go all the way to the floor and stick?
MIKE
http://www.dav.org/
MJM Powder Coating
Elizabethtown Ky.
http://www.cityprofile.com/
MJMPC is offline   Reply With Quote Quick reply to this message
Unread 05-29-2010, 07:41 PM   #9
92cherokeelimit
1992 XJ Cherokee
cool thx ......................!!!!!!!!!!!!
Unread 05-29-2010, 08:12 PM   #10
92cherokeelimit
1992 XJ Cherokee
no it dont go the floor and it dont stick really just moce it back up with my toe .
Unread 05-29-2010, 10:07 PM   #11
czjeeper
Probably your rear wheel cylinders
US Army combat vet
2011 Grand Cherokee Laredo 3.6
Armed Forces Jeeps Member #125
Red Jeep Club Member #251
In the Portland/Vancouver area? Check 'em out! Piston's Wild Motorsports Club
Click here for 2.5L AX5 to AX15 swap
czjeeper is offline   Reply With Quote Quick reply to this message
Unread 05-31-2010, 08:59 PM   #12
92cherokeelimit
1992 XJ Cherokee
Ya well my back brakes dont work really ... and it seems like they make funny sounds can i just unhook em since they dont work then ill just fix them later
Unread 06-01-2010, 04:05 AM   #13
dodger889
A short answer NO! You can not disconnect the rear brakes fix them is the best thing to do.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline   Reply With Quote Quick reply to this message
Unread 06-01-2010, 08:02 PM   #14
92cherokeelimit
1992 XJ Cherokee
well i did and it seems fine its not like im gonna go far with it .But ya it still stops. And now im not wrecking my brake drum. only thing is the ebrake lights on now. lol
I dont have back brakes but i dont have the time to take that apart ill just not go far. But it seems to still stop just fine. I will fix it soon though I have never done drum brakes yet so i need to wait for my brother to help me.
Unread 06-01-2010, 08:22 PM   #15
monkeyhouse
Let me ask you a question. Why do you think they put brakes on all four wheels?
You're not just putting yourself in danger, you are risking other people's lives too if you put that thing on a public road, bad idea. Maybe you should trade that jeep in for a much safer bicycle. Oh and it's not a good idea to disconnect any of the brakes on that either, just FYI.
Come on guy, use your head.
First Jeep was an 1989 YJ, 6 cylinder 4.2L , 258. Nuttered and TeamRushed, Weber 38 DGES, Now, I'm venturing into the world of Grand Cherokees
monkeyhouse is offline   Reply With Quote Quick reply to this message
