#1 | |
Brake pads help
Replacing them on My 90 wrangler today but it looks like I need a special tool anyone know what it is and any other tips would be greatly appreciated.
#2 | |
1988 Red Wrangler 2.5L 4 banger soft top, half doors pioneer cd deck, sony xplode speakers cragar rims/30" continental soon to come: 2.5 spring lift 1" body 31" tires (i like fender clearance :) ) [COLOR=Red]Red Jeep Club #297[/COLOR] |
#3 |
I also have a 90 and mine did not require anything special tools. Could you be more specific with what this tool would be for, Caliper Bolts, clamps, etc.... Let me know. I should be able to help you
#4 | |
#5 |
Yes, you need Torx bits for your ratchet.
'93 YJ 2.5 Jasper; 5 speed All stock, waiting to be reborn. 6/19/05 ...2" BDS suspension lift...the rebirth has begun!!! ONE NATION, UNDER G O D Support It, or Leave It! |
#6 | |
Join a 4x4 Club
'93 YJ, '02 GM 4.3 Vortec V6, SOA, dual ARB's, 8.8+D30(w/WarnHubs), 4.88 gears, 35" Trxus M/T's, AX15, 15x7 wheels, NP231+4:1+SYE+2LO, York OBA, Warn M8000, no top or doors Apr-Oct. Member and Web guy: New Mexico 4 Wheelers |
#7 |
My 1990 is not torx it is a 12pt 7/16 socket for the caliper bolts.
1990 Wrangler, 4.2L, 4.0 Head, Gibson Header, Mopar MPFI, ARB Snorkel, ProComp 4" lift, 33X12.5" AT, Superior Super 35 Axle w/ARB, Disk Brake conversion on rear. ARB in front D30, 8000lb Mile Marker winch, homemade rear bumper with swing away tire carrier. Extended flares. |
#8 |
Thanks All I guess I'll get the tools needed and get busy lol.
#9 | |
That is exactly what mine is. Don't be ashamed of not knowing, ask questions and you will learn a lot. Although it is Highly Recommended that you do go out and Spend the $15.00 for a Haynes or Chilton Manual. I bought both because I like the Wiring schmatics in one more than the other. Good Luck with the pads. |
#10 |
Jeep. Jeep? Jeep! Jeep.
I want to say my '89 had allen bolts holding the caliper on. Been a while since I did the brakes, but I do remember needing a hex head key to get them off. Might look like a recessed star pattern if it's dirty.
1989 Jeep Wrangler - Daily Driver and project - Red Jeep Club #216, NRA Jeep Club #5 1967 Chevelle SS396 - Main Project <--454, TH400, 4.10's, FAST 1982 Caprice Classic - Another project <-- 350/700R4, 4 wheel discs 1979 Honda Civic CVCC - Yet another project <--goal of 60 mpg |
#11 |
Count the points.
If it has six points it's recessed (socket goes into the bolt not around it) it's a hex probably 3/8in. If it has eight and it's recessed it's a torx. If it has 12 and isn't recessed (socket fits over it like a normal bolt) it's a 12pt socket. Simple enough. |
#12 |
WOW Awesome info Guys thanks a ton. You Guys are gonna make this easy..
#13 |
Got the 7/16 12 pt socket and no fitty the bolty it definately looks like a torx I dont know....Im gonna take it to a FREE brake place in the morning for inspection and ask them what the???
Let you know tommorow.. ![]() |
#14 |
Did they ever use reverse torx on the calipers?
#15 |
It is a 12 point socket and it is a very tight fit, especially if it's been a while since they've been changed. However you're making a lot of extra work for yourself taking those out. That is your caliper bracket not your actual caliper. Your caliper is held on with an allen head bolt (standard or metric I'm not sure). These two bolts go through the caliper (whcih is also the same bolts that allow the brakes to slide in and out when applied so make sure they are greased),and thread into the bracket itself. If your barcket is bent then remove it, other wise leave it in place and remove just the caliper. If it sounds confusing send me your e-mail and I'll shoot some pics over to you. I have one sitting on my deck still attached to the bracket.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
