Brake line and E-brake Question - JeepForum.com
post #1 of 44 Old 12-01-2005, 08:29 AM Thread Starter
vdubstreets
I've got a couple questions before i tackel my next problem...
I have a hole in my brake line somewhere and i think i knwo where it is because i can see a dark spot around it. On the rear axel there is a L shaped thing where 4 lines come in/out. Two lines go to each of the drums (im going to replace both because i think thats where the leak is) one line goes to the master cylinder, but what is the 4th? Do they sell these lines pre-bent or do i bend them myself? where can i buy drums for my jeep cheap online ( iknow usaly online they are cheaper than napa).
my second question is my e-brake is stuck on the on position and it doesnt relase when you pull the handle. What is peoples expierce with this, what could the problem be? do i have to replace the cable all the way back? is it the brake assembly itself? I konw theres a recall on this , but i dont hink that thats the problem.
thanks for all your help, it seems like one problem after the next.
vdubstreets is offline
post #2 of 44 Old 12-01-2005, 08:58 AM
Mr. Notorious
The fourth line is most likely the axle breather.
I know you can get the line from the master to that block, but I'm not sure about the lines to the drums. They're pretty much a straight shot. Just get some line from napa and bend them yourself.
As for the ebake, I know I had to add a stonger spring to pull it back up. Does it come up if you pull it up by hand? If not, your cables could be pretty well rusted. Have fun
1992 4.0HO 5spd -- BDS 3.5" lift -- 33x11.5 M/T's -- Gibson Cat-Back -- 8.8 with 4.10's -GONE
1967 FJ, linked, 350 chevy, 35's, arbs, blah blah...
2002 TJ
"If you're not moving ahead, you're falling behind"
Mr. Notorious is offline
post #3 of 44 Old 12-01-2005, 12:00 PM
jonnyri
jonnyri's Avatar
1 - I just did all four wheels with new brake lines. Bought bulk lines, bent over a beer bottle and screwdriver handle - I bought a bender at first but it was a nightmare. They're not to bad to bend by hand. Going across the rear axle is pretty easy. Just make sure that you use penetrating fluid on the drums.... Also when removing from the drums snap off the line and get a good socket on the connector. It's soft metal and is prone to round over with an open ended wrench.
2 - The ebrake recall was for it releasing when engaged. it doesn't sound like your's is even working. check the springs, tension, etc... on the cables and look for anything broken or loose.
jonnyri is offline
post #4 of 44 Old 12-01-2005, 01:06 PM Thread Starter
vdubstreets
where can i purchase a e-brake cable and drums? how hard is that to replace? the problem is the ebrake is engaged and NOT disengaging. i tried by hand and it wont budge.
do you remember the lenth of the lines otherwise ill just go mesure them whe ni get back to the garage.
post #5 of 44 Old 12-01-2005, 02:29 PM
91GTA350
if you end up buying straight lines, they arn't that hard to bend with your hands. Just take your time. You can feel when they will want to start to kink. I would recomend buying a spare or a short length of line to practice on if you have any tight bends. Also, if you need to splice into an existing line without a flair, use a compression fitting. You can get them at the auto parts store, but don't tell them they are for your car. They aren't DOT legal, but they work great. A friend has 5 of these compression fittings on his CJ and he has no problems.
-89 sahara 258: HAD a peugot and a d35
5/15/05 - took ownership and started money pit
9/17/05 - found a 3.5' deep water hole
2/18/06 - destroyed spiders in d35
4.2/AX-15/NP-231/SYE/30/8.8/3.55/RE 2.5"/31"
91GTA350 is offline
post #6 of 44 Old 12-01-2005, 04:21 PM Thread Starter
vdubstreets
I've bent lines before for a clutch on my CJ so I;m not too worried.
I just want to get my Ebrake situation fixed, anyone else have the same problem E-brake is engauged wont disengauge. Possibly as the other guy said, the cable is bad? i think im going to replace that, if i remove the cable will it disengauge the ebrake for the mean time?
post #7 of 44 Old 12-01-2005, 05:48 PM
dcafaro
I got my e-brake cables from quadratec. Just put them in last weekend I've yet to adjust them though. They are easy enough to put in just make sure to attach them to the e-brake within the drum first, before you attach them to the equalizer, much easier. Also make sure you spray plenty of PB on your equalizer days ahead so you can loosen the nut without fighting it.
dcafaro is offline
post #8 of 44 Old 12-02-2005, 10:33 AM Thread Starter
vdubstreets
what was the process, does it just run dirrectly from the brake peddle to the rear is it both drums or just the drivers side? i havent really looked to into it just saw it run to the drives.
if i start taking the cable off, will it release?
post #9 of 44 Old 12-02-2005, 01:12 PM
ylojelo
Ive heard that to bend tubing , if you have it packed with sand while you bend it it will keep it from kinking. Could be bs, I've never tried it and just throwing it out there
'12 JKU Rubicon
'93 YJ stock
'01 XJ + 2" OME
ylojelo is offline
post #10 of 44 Old 12-02-2005, 01:32 PM
sentinal02
H2 Recovery Team Member
sentinal02's Avatar
that's fine for larger diameter stuff, but for 3/16" brake line i wouldn't recommend it. no way to really know if you get all the sand out and if it ends up in your cylinders or calipers it can tear apart your seals.
vdub, the adjustment for the cables is located on the driver side, just behind the front seat near the fuel filter. there's a Y bracket with a long threaded stud that threads into the attachment to the front cable that comes from the pedal. undo that nut holding the stud in place and you can take the tension off the rear cables. the pass side cable routes over the drive shaft just in front of the fuel tank. just had to replace mine because someone tightened them to the point they were fully engaged but because the pads were worn it wouldn't hold. unfortunately they were like that for so long the cables froze and i couldn't loosen them to get the new pads on. i got mine from quadratec as well, but it seems like the DS cable is like a 1/2" longer than the PS. where they meet at the equalizer one tightens up before the other and it starts engaging that side. I'm going to modify it to run dual e-brakes though so i'm not too worried. poor man's locker
RIP: '88 YJ 2.5L Ax-5 NP231
Posi-Loked. Herculined. Optima yellow top. 1" Shackle, 2" BDS. Cragar 397's Aussie front.
92 YJ 4.0L Ax-15 231
5" springs, 1" shackle 31's or 35's depending on my mood
sentinal02 is offline
post #11 of 44 Old 12-02-2005, 01:38 PM
schitzangiggles
King of Macastan
schitzangiggles's Avatar
The brake line bender tool is only a coupla bucks. Do you really need a reason to buy more stuff for the jeep?
"Axeheads are supposed to be sharp, but you are one blunt tool."
FLynes
If you love wealth more than liberty,the tranquility of servitude more than the animating contest of freedom, go home from us in peace. We seek not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains sit lightly on your shoulders and may posterity forget that you were our countrymen.
-Samual Adams
A government big enough to give you everything you want is big enough to take everything you have.
Thomas Jefferson
Calling Illegal Aliens "Undocumented Immigrants" is like calling drug dealers "Unlicensed Pharmacists"
Nemo Me Impune Lacessit
"No one provokes (attacks) me with impunity".
"Your right, the Tea Party and the OWS are the same, just like the America Revolution and the French Revolution were the same. The only problem is the American Revolution ended with Liberty, Freedom, Justice for all and a shining light upon a hill. The French Revolution ended with lynchings, guillotines, murder and socialism. So yeah, I could see how one could confuse the two..."
Mac Wilson
schitzangiggles is offline
post #12 of 44 Old 12-02-2005, 04:10 PM
Macabre
Macabre's Avatar
1990 XJ Cherokee
Just went through the stuck e-brake thing.. It wouldn't disengage, and thus my Jeep couldn't move.
I replaced the two rear cables and it seems to have worked. They were pretty beat. Both were available at the local auto parts store.
1990 XJ, 2-door, 4.0, AW4, NP231, 3" lift, 32x11.5 Interco SSR's. 104,000 miles.
Macabre is offline
post #13 of 44 Old 12-06-2005, 05:28 PM Thread Starter
vdubstreets
anyone know off the top of there head before i go to the barn to work on my jeep what size the brake lines are?
post #14 of 44 Old 12-06-2005, 05:41 PM
crazymon01
crazymon01's Avatar
i had a similar problem with my ebrake... ended up needing to jus tension the cable... easy fix unless its rusted too.. but then its not all that bad or expensive to replace that either... if ur brake is not engaged while the pedal is pushed to the floor u may also have a broken cable.
4.0
I6
ARB snorkle
307 -> 411 gear swap
lock rite locker on the dana 35
33 x 12.50 Mickey Thompson radial MTZ
4.5" Rubicon Express heavy duty Suspension Lift
currie boomerang shackles
8,000 lbs. Winch
bikini top
tonneau cover
pictures??
crazymon01 is offline
post #15 of 44 Old 12-06-2005, 09:03 PM Thread Starter
vdubstreets
its engauged.
Brake line question JeepPirate TJ Wrangler Technical Forum 3 06-11-2007 07:06 PM
Removing Brake hose from Hard brake line?? chupacabrah YJ Wrangler Technical Forum 11 03-19-2007 02:29 PM
brake line question scrnnmssuck TJ Wrangler Technical Forum 4 12-10-2006 10:47 AM
RE Rear Brake Line and E-Brake Cable Questions? Jeep4Rox TJ Wrangler Technical Forum 1 01-12-2006 03:42 PM
8.8 Brake question - connecting to the exisiting hard brake line? BNovak TJ Wrangler Technical Forum 2 06-10-2005 02:25 PM
