Brake Lights not working?? - JeepForum.com
post #1 of 6 Old 01-15-2014, 11:21 AM Thread Starter
relso1
Hi all,
I'm trying to get my 92 YJ on the road, but have recently discovered that my brake lights won't turn on! I have check both filaments in the bulbs, the brake switch works (which I only discovered after spending $20 on a new one ) I've checked fuses, relays, etc. There is power going to the switch, and both turn signals and hazards work fine.
Any ideas??
relso1 is offline
post #2 of 6 Old 01-15-2014, 11:36 AM
jaycal3
May be a long shot but sounds like you checked everything else... here is my old thread for a similar issue:
http://www.jeepforum.com/forum/f12/t...-bulb-1161064/
The long and "short" is that I removed the housing for the left tail light and found a broken wire - you can scroll through and see the pics...
93 YJ, 6 cyl,3.5" BDS,1" Prothane BL,1/2" booms, 33" Mickey Thompson MTZ on MT Beadlocks.
Do your part for Leukemia research - help find a cure.
KCCO
jaycal3 is offline
post #3 of 6 Old 01-15-2014, 03:39 PM Thread Starter
relso1
Thanks, but after an hour and a half of my electrical engineer friend poking around under the dash with a power probe, we found it was just a bad connection in the wiring harness
relso1 is offline
post #4 of 6 Old 01-16-2014, 09:08 AM
Que89YJ
Relso, which connection? Just curious.
Que89YJ is offline
post #5 of 6 Old 01-16-2014, 04:29 PM
mark1305
mark1305's Avatar
I had a problem with mine once, and I've put the details out of mind. But IIRC someone told me in traffic the brake lights weren't working. Got it home and the turn signals and flashers worked, but not brake lights. Turned out the part of the turn signal switch that cancels the brake signal to the turn signal so it flashes failed for both sides. So signals and flashers worked, but brake lights on both sides were "canceled". New switch and new cancelling cam fixed it. At least that's how I remember it. And it took some study of the circuit diagrams to finally locate the problem. I'd never heard of this before or since.
mark1305 is offline
post #6 of 6 Old 01-16-2014, 04:44 PM
1320yj
I had same problem it was a bad connection at the turn signal switch connector at the bottom of the steering column.
1995 2.5 5 Speed SOA +2.5 rough Country lift, High steer kit , 33x12.50 Mud Rovers
1320yj is offline
