Brake lights issues, 94 Wrangler YJ Sahara - JeepForum.com
post #1 of 11 Old 02-06-2013, 07:56 PM Thread Starter
wcorp87370
My tail break lights and turn signals work fine until I turn on my lights on. Once I turn the lights on nothing in the back works, however if I turn my hazard lights on, brake lights and hazard lights work in the back. Front lights work well. Any ideas what to check?
wcorp87370 is offline
post #2 of 11 Old 02-07-2013, 06:51 AM
Que89YJ
Go through all the grounds for the lights. Headlight grounds on the side of the radiator, tail lights ground through the tail light assembly mounting screws. Clean them and make sure they are all secure.
Que89YJ is offline
post #3 of 11 Old 02-07-2013, 07:07 AM
OldSkull75
I had a similar issue with my 94. When I turned the head lights on the wipers came on too. It was the grownd wire behind the headlights. I unscrewed them, cleaned and re secured the ground.
OldSkull75 is offline
post #4 of 11 Old 02-07-2013, 01:24 PM Thread Starter
wcorp87370
Thanks guys, I will check it out tonight. will let you know
post #5 of 11 Old 02-07-2013, 06:20 PM Thread Starter
wcorp87370
I did grounds on headlights but could not figure out the tail lights. Previous owner put the tail light guards on it. NOt sure how to get in.
post #6 of 11 Old 02-07-2013, 06:46 PM
DirtKar
I pledge allegiance.
DirtKar's Avatar
If you can see the 4 Phillips head screws (you should be able to see them)on the face of the lites, remove them. This will allow you to remove the lens. Once that is off you will see 3 bolts holding the housing onto the body. Remove those and the guard will come off. If you reach up into the corner of the body from below you will find the connector in the wire harness that allows you to remove the whole thing. Make sure hat he ground wire connection inside the lite housing is good and secure.
Luck Favours The Prepared
YJOTM JULY 2014
DirtKar is offline
post #7 of 11 Old 02-07-2013, 07:57 PM
bigbossd1030
Check the wide pigtail under the steering column. Make sure all the pins on the inside of it are connecting properly. It is the pigtail that is clipped into the side of the steering column under the dash.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #8 of 11 Old 02-07-2013, 08:07 PM
ROTTEN
I would clean the grounds and mating surface of the tails and also try them without the tail light guards on.
I'm new
ROTTEN is offline
post #9 of 11 Old 02-07-2013, 08:17 PM Thread Starter
wcorp87370
I got it. It was one screw in the left tail light which was controlling the whole thing. Was a little rusted. Once I cleaned it everything worked fine. Thanks for your help, guys
post #10 of 11 Old 02-07-2013, 08:19 PM Thread Starter
wcorp87370
Can't believe the whole tail comes down to one screw, but what the hack
post #11 of 11 Old 02-07-2013, 08:21 PM
DirtKar
DirtKar's Avatar
Thanks for posting the fix. You HAVE to have good grounds or all kinds of weird things can happen.
YJOTM JULY 2014
DirtKar is offline
brake , lights , YJ
