brake lights don't work - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > brake lights don't work
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineThe Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!
Unread 05-30-2007, 02:49 PM   #1
mcruickshank
I went for an inspection today and found out my brake lights don't work, but everything else does. Turn signals work. Parking lights work.
I checked the fuse (but that shouldn't be the problem since the parking lights work).
I put a voltmeter on the brake light switch that is located behind the dash. It appears to be working correctly, yet I am not 100% confident that I tested it correctly. Does anyone know the correct leads to test?
Anybody have a similar probelm?
Thanks in for any help,
cruick
mcruickshank is offline   Reply With Quote Quick reply to this message
Unread 05-30-2007, 03:15 PM   #2
Brian2o0o
My brakelights quit working a while back.... it was the fuse. If I remember correctly the headlights/parking lights were still working even though the brake lights weren't.
2013 JKU sport, 3.25 RC lift, 35" BFG KM2s, JCR bumpers, Smittybilt winch
Brian2o0o is offline   Reply With Quote Quick reply to this message
Unread 05-30-2007, 04:22 PM   #3
alandchris
i had a problem with one of my brake lights - the grounding was bad - the factory ground appeared to be from the 3 bolt/screws that attach the light housing to the body of the jeep - mine did not work because of some 'bondo' work done near the light - so the bolt/screws did not go into metal -
I ran a copper wire from the bolt/screw up to a metal piece on the inside of the jeep - all good now. Funny tho - if this is your case, both would be ungrounded.
alandchris is offline   Reply With Quote Quick reply to this message
Unread 05-30-2007, 09:56 PM   #4
dbikers
i had the same problem a while back..it ended up being the wires going to the switch on the pedal...i put new ends on them and it worked like a champ...on a different note, you have to be a contorsionist (sp??) to get under the dash and work ...i'd check the switch and wiring....
STUPID HURTS.......OUCH!@#$
dbikers is offline   Reply With Quote Quick reply to this message
