Brake lights don't work - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Brake lights don't work
Unread 07-11-2012, 07:30 AM   #1
melianguidry
I did the obvious fuse checking - even went ahead and checked every single fuse in the Jeep, they all work
Headlights, taillights, turn signals, reverse lights, hazards all work
Checked the bulb, both filaments are good
Didn't replace the brake light switch, but I did unplug the old one, plug in the new one and pressed and released the button repetitively to no avail
I was told that if the turn signals work, that's a good sign the wiring is still good, as the turn signal and brakes use the same wires
I'm now at a loss...any ideas?
melianguidry is offline   Reply With Quote Quick reply to this message
Unread 07-11-2012, 08:43 AM   #2
notmyj
Are you getting power into the brake light switch? How about out of the switch?
www.pghoffroad.com
My SOA Build
Recovery Gear Basics
My BUDGET York OBA Install
Budget Welding Cart
Carling Contura Switch Panel
If it has tracks, tires or tits, its gonna cause a problem.
"Everytime someone "upgrades" a D35, an angel looses its wings."
"Dizzy" - What SnoopDog would call a Distributor if he was a mechanic. I cringe every time I hear this moronic term
Originally Posted by Warren Zevon
Send lawyers, guns and money. The **** has hit the fan...
92, 4.0, AW4, 8.8, D30, 15x10, 37's, SOA etc, etc
92, 2.5, 30, 8.8, 4.88, Locked, Winch, 15x8, 35's, 3.5" (RIP)
notmyj is offline   Reply With Quote Quick reply to this message
Unread 07-11-2012, 05:37 PM   #3
JWELK
Try activating the 4 ways (hazards) several times. Seems to be a common problem
JWELK is offline   Reply With Quote Quick reply to this message
Unread 07-24-2012, 11:11 AM   #4
melianguidry
Sorry for my own failure to keep up here and close the loop.
After much searching I did both things recommended above to no avail. I was finally able to get a friend to take a look at the Jeep and he noticed my own idiocy. The fuse for the brake lights was in the wrong spot. There were a few other electrical problems I was having before the brake lights, so I pulled all the fuses to check them. Apparently I put this one back in the wrong spot.
He was able to fix the other issues by replacing a bad relay.
Unread 07-24-2012, 12:24 PM   #5
Rproject
1987 YJ Wrangler
Don't you hate it what you have "DOH!" moment?
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread: http://www.jeepforum.com/forum/f22/r...hread-2164793/
Rproject is offline   Reply With Quote Quick reply to this message
Unread 07-24-2012, 12:48 PM   #6
bogleparsons
Takes a real man to admit his mistakes.
except me I don't make mistakes.
I thought I did once but I was mistaken.
If it's not supposed to move and does use duct tape.
If it's supposed to move and doesn't use WD40
bogleparsons is offline   Reply With Quote Quick reply to this message
Unread 07-24-2012, 12:58 PM   #7
seraph_rapture
I logged in to suggest checking the grounds behind the taillights and the relay. Looks like you beat me to it!
seraph_rapture is offline   Reply With Quote Quick reply to this message
