brake lights don't work - JeepForum.com
post #1 of 4 Old 05-30-2007, 01:49 PM Thread Starter
mcruickshank
I went for an inspection today and found out my brake lights don't work, but everything else does. Turn signals work. Parking lights work.
I checked the fuse (but that shouldn't be the problem since the parking lights work).
I put a voltmeter on the brake light switch that is located behind the dash. It appears to be working correctly, yet I am not 100% confident that I tested it correctly. Does anyone know the correct leads to test?
Anybody have a similar probelm?
Thanks in for any help,
cruick
mcruickshank is offline
post #2 of 4 Old 05-30-2007, 02:15 PM
Brian2o0o
My brakelights quit working a while back.... it was the fuse. If I remember correctly the headlights/parking lights were still working even though the brake lights weren't.
2013 JKU sport, 3.25 RC lift, 35" BFG KM2s, JCR bumpers, Smittybilt winch
Brian2o0o is offline
post #3 of 4 Old 05-30-2007, 03:22 PM
alandchris
i had a problem with one of my brake lights - the grounding was bad - the factory ground appeared to be from the 3 bolt/screws that attach the light housing to the body of the jeep - mine did not work because of some 'bondo' work done near the light - so the bolt/screws did not go into metal -
I ran a copper wire from the bolt/screw up to a metal piece on the inside of the jeep - all good now. Funny tho - if this is your case, both would be ungrounded.
alandchris is offline
post #4 of 4 Old 05-30-2007, 08:56 PM
dbikers
i had the same problem a while back..it ended up being the wires going to the switch on the pedal...i put new ends on them and it worked like a champ...on a different note, you have to be a contorsionist (sp??) to get under the dash and work ...i'd check the switch and wiring....
STUPID HURTS.......OUCH!@#$
dbikers is offline
Brake Lights not working...all other lights work Dashash TJ Wrangler Technical Forum 15 12-28-2016 01:20 PM
brake lights doesnīt work catalan TJ Wrangler Technical Forum 6 10-08-2009 08:02 AM
brake lights don't work when lights are on driftbandito YJ Wrangler Technical Forum 3 12-02-2008 01:35 AM
rear brake lights don't work daigljus TJ Wrangler Technical Forum 4 08-05-2008 09:11 AM
brake lights don't work at all. jeep n00b YJ Wrangler Technical Forum 11 03-12-2008 06:35 PM
