Brake Lights - JeepForum.com
post #1 of 6 Old 12-14-2011, 07:38 AM Thread Starter
spawnofsatan
Brake Lights
Maybe someone can help me with my 1990 YJ Issue...
I replace my brake lights with flush mount LEDs a year ago everything works until last night. When my headlights are off and I press the brake pedal one of my brake lights(passenger) is not working now when I turn on the headlights both work fine turn signal ect. The only thing I did was upgrade my headlight wiring harness which I ordered from Eautoworks.
spawnofsatan is offline
post #2 of 6 Old 12-14-2011, 07:52 AM
copleydad
copleydad's Avatar
When you upgraded the harness, you added a new relay and new wiring? New headlights? HID? Halogen? Correct size wire?
Sometimes it's easier to undo what you did to see if you do have tail lights, and you probably do, like you did before you did the upgrade many people do, oftentimes incorrectly, like many did, before doing any modifications like you did.
'89 Islander 4.2l 5 speed
'14 Grand Cherokee Limited 3.6
One Jeep is Never Enough
copleydad is offline
post #3 of 6 Old 12-14-2011, 08:51 AM Thread Starter
spawnofsatan
The harness is all plug and play I'll try it during my lunch hr.
post #4 of 6 Old 12-14-2011, 01:39 PM
BlueDanube
Could likely be a bad ground on one of the tail lights. Older Dodge Ram pickups had this issue when the left rear taillight ground would get bad contact.
JEEP
Just Entertaining Every Person
BlueDanube is offline
post #5 of 6 Old 12-17-2011, 12:22 AM
SnowdogMarc
X2 on the bad ground.
l We're here for a good time. Not a long time. So have a good time the sun can't shine every day.
l_______
/l ,[_____],
l---L -[]lllllll[]-
()_) ()_)--o-)_)____________VE6-SDG
SnowdogMarc is offline
post #6 of 6 Old 12-17-2011, 06:48 AM
dodger889
When you wired these led in what wire did you use for ground?
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
No turn signals, brake lights, or emergency lights canspam324 TJ Wrangler Technical Forum 3 10-16-2011 08:42 PM
Lights on, Blinker doesnt work and Brake Lights stay on...? Beefstew TJ Wrangler Technical Forum 1 09-01-2011 10:42 PM
Just installed LED Tail lights but reverse lights come on with brake lights... Yarney05 TJ Wrangler Technical Forum 19 04-22-2011 11:13 AM
89 YJ Electrical Issues blinkers/ dash lights come on with Brake lights Cajun90YJ YJ Wrangler Technical Forum 9 10-03-2010 05:33 PM
brake lights, ok; tail lights/side markers/turn signals not.... help? LoneJeeper TJ Wrangler Technical Forum 2 09-12-2005 08:18 PM
