Brake light goes out when turn signal on - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Brake light goes out when turn signal on
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFord Explorer 8.8 4340 Chromoly Axle Shaft Kit C Clip Elim07-15 jeep JK Spare Tire Carrier Delete Plate
Unread 06-28-2015, 09:12 PM   #1
Firestix101
Just bought a 88 wrangler recently. The hazards work, but the turn signals do not. The fuse is good, the flasher cartridge is good, the toggle switch "clicks."
No "arrow" dash illumination when turn signal on. WHEN APPLYING BRAKE AND TURN SIGNAL THE BRAKE LIGHT TO THE CORRESPONDING SIDE GOES OUT. So, when driving down the road and applying brake and turn signal to turn left, the left brake light will go out while right side stays on. The same thing happens to the right side when applying brake and turn signal. Where do I go next??
Firestix101 is offline   Reply With Quote Quick reply to this message
Unread 06-28-2015, 09:27 PM   #2
jred
Check the rear bulb contacts. I think that's what it was when mine did it.
jred is offline   Reply With Quote Quick reply to this message
Unread 06-29-2015, 06:29 AM   #3
Firestix101
Nope, bulbs are clean and new.
Unread 06-29-2015, 06:38 PM   #4
coleslaw
1987 YJ Wrangler
check all the ground wires...
Coleslaw
[COLOR="RoyalBlue"][I]A country that tries to spend itself to prosperity is like a man standing in a bucket and trying to lift himself by the handles.[/I][/COLOR]
[I]Winston Churchill[/I]
87 YJ I6, nuttered and rushed, 2.5" lift, 31x10.5, custom made f&r bumpers, Mojave heater, TJ flares, Superwinch S9000, hm swingout tire carrier, tool drawer, custom electical control, and more in the works...........
coleslaw is offline   Reply With Quote Quick reply to this message
Unread 06-29-2015, 08:18 PM   #5
Firestix101
Fixed it. Loose fuse receptacle.
