Brake light on dash??? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Brake light on dash???
Lifetime LED on Sale at Baseline 4x4 Outfitters LED Light Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRaceline/Allied Wheels on Sale NOW !
Unread 02-16-2011, 02:33 PM   #1
KYJeepMan1
2009 JK Wrangler
Today i went for a short drive and noticed that the Brake light on the dash cluster was on. I use my parking brake all the time and i've never seen this light on before. My parking brake does not seem to be stuck on, because i can move the jeep with my foot. But my brake pedel does go to the floor some times now. When i bought the jeep a week ago i noticed that the brake pedel had alot of travel. Now there seems to be a problem. Any advice??? What to do next???
Thanks
KYJeepMan1 is offline   Reply With Quote
Unread 02-16-2011, 02:41 PM   #2
aldrichg9
My back brake line is broken and leaked all the fluid out causing the light to come one.
This is not only the parking brake light - its the brake system warning light as well.
Check your fluids first and check for leaks.
I'd say with lots of pedal travel you have a leak and/or lots of air in a line somewhere
aldrichg9 is offline   Reply With Quote
Unread 02-16-2011, 02:44 PM   #3
rdsk8ter
1982 CJ7
low fluid will do that too refill and check all hoses
rdsk8ter is offline   Reply With Quote
Unread 02-16-2011, 02:51 PM   #4
KYJeepMan1
2009 JK Wrangler
The fluid level is fine, and i don't see a leak at any of the wheels. Maybe i should try to bleed the system first. Is there any speical order to bleed the brakes?
Also the light has never come on as i use the parking brake everyday. That seems odd to me that it has never worked until today. It should come on when the parking brake is on.
The Haynes manual says it will stay on until the system is repaired.
Unread 02-16-2011, 02:58 PM   #5
SPCMilligan87
1987 YJ Wrangler
Air
Bleed the Brakes really REALLY good! Then disconnect the battery and your problem should be solved. If your pads are too worn the light will come on also but it sounds like you have air in those lines.
SPCMilligan87 is offline   Reply With Quote
Unread 02-16-2011, 03:01 PM   #6
SPCMilligan87
1987 YJ Wrangler
Bleed the brakes Pas rear, driver rear, pas front, driver front. farthest from master cyl to closest
Unread 02-16-2011, 03:14 PM   #7
KYJeepMan1
2009 JK Wrangler
Ok Thanks for the help. I'll start there.
Unread 02-16-2011, 04:09 PM   #8
Mean Max
Don't poke the bear
Mean Max's Avatar
Not completely accurate.
Yes, bleed the brakes really good to start with. But I'll bet you're having an issue with a leak. If your fluid level does not deplete, you probably have a bad master cylinder. The light on the dash will only come on from 1 of 2 switches. Either the parking brake switch, or the proportioning valve switch. Unhooking the battery will not affect anything & would be a waste of time. Brake pad thickness will not cause the light to come on, there are no pad thickness sensors.
Most likely, your master cylinder is leaking internally, or into the power brake booster.
Max
Sent from my HTC Incredible Droid
Click here to see all of my different albums on Photobucket.
Choose any album to see all of my pics!
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline   Reply With Quote
Unread 02-16-2011, 06:32 PM   #9
GA05SPORT
On my Jeep that I just picked up I curiously removed the piece of tape covering a section of the warning lights in the dash. It revealed a lit BRAKE indicator. Looking at the back of the parking brake I discovered that the "plunger" portion of the parking brake switch was seriously messed up. Disconnected the wiring tagged it and tuck it away. Presto, BRAKE indicator out.
GA05SPORT is offline   Reply With Quote
Unread 02-16-2011, 06:39 PM   #10
GaJeepy
Max
After having a terrible brake problem and fixing everything my dash light was still on. My step dad, a retired mechanic for the air force told me to crank my jeep and mash the brake pedal as hard as possible. This made my light go off. I'm just wondering if you have ever heard of this or tried it?
livin' out the music de punk
MUD FLIES WHEN YOU'RE HAVING FUN. ~Red Jeep Club #574
GaJeepy is offline   Reply With Quote
Unread 02-16-2011, 06:47 PM   #11
Mean Max
Don't poke the bear
Mean Max's Avatar
Yes, I have heard of that. That's the "old school" way of balancing the proportioning valve.
When there's a fluid pressure issue, the spool valve gets off balance & stays in one end of the valve body. Massive pedal pressure helps it re-center in the body which allows the light to stay off.
Max
Unread 02-16-2011, 07:02 PM   #12
GaJeepy
Max
That's pretty much how my step dad explained it. I couldn't think of the name of the valve. Always enjoy your posts.
Unread 02-16-2011, 07:06 PM   #13
KYJeepMan1
2009 JK Wrangler
I unpluged the proportioning valve switch under the master cylinder and the light went out. So i will have to bleed them tomorrow. Also i'll check each wheel for a leak.
Unread 02-17-2011, 10:20 AM   #14
KYJeepMan1
2009 JK Wrangler
UPDATE: I took the Jeep to a shop and they tryed to bleed the system. They could not get a drop of fluid out of the lines. So he tryed at the master cylinder and still no fluid. They replaced the master cylinder and now the brakes are good as new. BUT the light is still on. They said it was the switch under the master cylinder would not reset. Can you quys give me any advice on what to do now. Can the valve with the switch be takein apart and repaired or replaced?
Thanks...
Unread 02-17-2011, 10:27 AM   #15
Que89YJ
I would take the jeep back to them. You paid to have it repaired and the light on is not repaired.
Que89YJ is offline   Reply With Quote
