-   -   brake issues (http://www.jeepforum.com/forum/f12/brake-issues-1550029/)
91RedSled 07-16-2013 11:55 PM
brake issues
I'm finally almost done with my axel swap and spring over. Its been a long time since I started it. My final issue is that I can't seem to be able to bleed the brakes. I have went thru three 32 once bottles of fluid. I bleed them until I get no more air out but still no pressure on the peddle. I've done it four times so far. If I pump the brakes I get the pressure and it holds but when I bleed them again I get air. Where could I be getting air if the pressure holds after pumping them???? I'm baffled. Please help
fishnic 07-17-2013 07:11 AM
The most common answer you will find is that the calipers were installed on the incorrect side and has the bleeder pointing down. verify this first
91RedSled 07-17-2013 02:41 PM
DUHHHH. I kinda feel stupid now. LOL I found that the rear brake adjusters are frozen. Hopefully a rebuild kit on them will do the trick.
The time now is 05:04 AM.
