brake hose won't disconnect from brake line - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > brake hose won't disconnect from brake line
FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire
Unread 06-12-2013, 12:20 PM   #1
killakeane
1987 YJ Wrangler
I'm not sure why I sprayed it with wd40 but not the pb which I heard works wonders. I got the banjo off but can't get the hose disconnected the metal line just keeps turning as I turn the wrench. Any input would be greatly appreciated.
[B][I]Staten Island[/I], NYC
[/B] [COLOR="Black"]87YJ[/COLOR] 4.2L 5 spd with some cool stuff done to it.
[COLOR="Red"][B]ΜΟΛΩΝ ΛΑΒΕ [/B][/COLOR]
[COLOR="Navy"]US Navy Jeep Club Hull# 231[/COLOR]
[COLOR="DarkRed"]Maritime Offroading Club[/COLOR]
killakeane is offline   Reply With Quote Quick reply to this message
Unread 06-12-2013, 12:30 PM   #2
PA_YJ19
Just take the hard line off and replace it too, by the sound of it it's prob seen better days. U can get it at advanced in sections of whatever length u need pretty much. They aren't very expensive either, also it's 3/16s line if u need to no. Otherwise ur only others option is heat it then spray it with pb, put a vise grip on the line and turn the other with a wrench. I just pulled mine off completely and replaced as mine all did what ur describing and were super rusty. I gave up on trying to massage it out and just ran new hard lines...
PA_YJ19 is offline   Reply With Quote Quick reply to this message
Unread 06-12-2013, 02:55 PM   #3
killakeane
1987 YJ Wrangler
yeah, guess that's what im going to do over the weekend or early next week when I have some time off.. i fought with it for about an hour hoping it'd come free at somepoint and i was wrong the medal line looked like a twizzler! how difficult was it for you to run the hard line from the master?
Unread 06-12-2013, 03:10 PM   #4
PA_YJ19
Not hard at all, for the one hard line that is really long u may have to get an adapter and connect 2 sections together. That was the toughest thing I ran into, once u get the old rusty ones out of there, it's all downhill.
Unread 06-12-2013, 03:55 PM   #5
killakeane
1987 YJ Wrangler
they sell the lines by the coil or what? im not sure what exactly too be looking for when i head to the store tomorrow haha, i followed the line today and its not too far that it has too go (front passenger) and while im doing that one i'll probably replace the front driver side as well..
Unread 06-12-2013, 04:02 PM   #6
dillonjm
You can buy it that way, yes, but its easier to buy pre cut lengths that have the ends already on them.
[B]03 Rubicon[/B] (Weekend Toy) [URL="http://www.jeepforum.com/forum/f176/marshals-03-rubi-2822258/"]Build thread[/URL]
[B]11 Ram 2500 [/B] - H&S tuned 6.7 Cummins (DD/Tow Rig)
[B]05 Liberty Limited[/B] (Wife's): Minor mods, OME/JBA Suspension, 245 70/17 Duratracs
dillonjm is offline   Reply With Quote Quick reply to this message
Unread 06-13-2013, 08:50 AM   #7
Destr0
You can either buy a coil of it and use the free loaner double flair tool most auto parts stores have, or you can buy the pre-cut lengths. If the main hard line from the front to the back is the issue then you may need to buy an adapter to connect two shorter lines together.
I somehow ended up as the brake guy and always end up running new hard lines for people so I have my own double flair tool and keep a bunch of fittings and lines in my shop.
PS> If you rent a loaner DF tool make sure it has all the pieces before you leave the store! Ask me how I know....
1994 Jeep YJ off road toy
1981 CJ7 SBC 350
2005 KJ Libertyt 4x4 CRD w/ 2.5" Frankenlift DD
Destr0 is offline   Reply With Quote Quick reply to this message
Unread 06-13-2013, 10:09 AM   #8
jbolty
jbolty's Avatar
Flaring lines is not all that hard but it is a skill to do well. If you measure with care you can replace all the hard lines on the entire jeep with pre flared sections for about $50. You will probably need one union for the front to back section and one for the piece running over to the right front wheel. Otherwise you can get enough different lengths to make it all fit perfectly.
If the rest of the brakes need attention it's a good time to replace everything and have all new parts with all good clean fluid. You will notice a difference.
If you live within wheeling distance of San Diego county, click here
jbolty is offline   Reply With Quote Quick reply to this message
Unread 06-13-2013, 10:43 PM   #9
killakeane
1987 YJ Wrangler
It's sold in kits for that, correct? like on 4wd, quadratec etc etc...? do you know where I could pick up a reasonably priced one? kinda working on a budget between my jeep, my living costs, college and of course the woman...
