brake booster and master cylinder - JeepForum.com
post #1 of 4 Old 06-25-2006, 02:38 PM Thread Starter
sandman'sjeep
might need to change these parts along with the metal tubing coming out of the master cylinder in the near future... has anyone done this project and is there any hiding things I should know about... thanks
sandman'sjeep is offline
post #2 of 4 Old 06-25-2006, 09:17 PM
ErikJordan
Pimp Hand
ErikJordan's Avatar
put in a booster and master from a 95+ yj/tj. you'll like the results
___________________________________________
What is all of this talk of Savvily designed products?
ErikJordan is offline
post #3 of 4 Old 06-28-2006, 07:22 AM Thread Starter
sandman'sjeep
just ordered proportioning valve , master cylinder and booster for my Yj... ouch ... I noticed a small leak from the booster so I decided to replace all these parts ... the only thing I couldn't order was the metal tubing (5 of them) that came out of the master and proportioning... called the stealership and they said they dont have them or couldnt order them... the tubing are covered with rust and I'm afraid that while removing them, they will either break or strip... anyone know where I could get ahold of these parts... weekend project
my only other choice or action is to PB the heck out of them, sandpaper them clean...
enjoy the forth of July guys and thank a solider for your freedom
post #4 of 4 Old 06-28-2006, 08:51 AM
Vancopbs
Vice grips (tight), tighten then loosen each line. After you soak them a bit, once they crack loose then use line wrenches. Good luck.
Van
Vanco Power Brake Supply
9738 Atlantic Ave
South Gate, Ca 90280
800-256-6295
323-563-1588
Vancopbs is offline
Master cylinder/Brake booster question Smitty1 YJ Wrangler Technical Forum 0 05-10-2009 08:32 AM
I need to replace my master cylinder & booster - Will This Work!!! mandng0 YJ Wrangler Technical Forum 23 04-01-2009 02:42 PM
Help with Brake Booster/ Master Cylinder Tompatt YJ Wrangler Technical Forum 13 10-27-2008 02:03 PM
Vanco Brake Master Cylinder/Booster goatboy YJ Wrangler Technical Forum 5 04-26-2008 10:28 AM
95 Brake Master Cylinder CjinPA YJ Wrangler Technical Forum 3 07-26-2006 01:05 AM
