Brake booster and master cylinder - JeepForum.com
post #1 of 13 Old 05-28-2011, 07:30 PM Thread Starter
Flingit1200s
2009 JK Wrangler
While I'm doing a bunch of brake work, I am going to replace the booster and master cylinder. I can't seem to find a thread I read a long time ago that identified a specific year of YJ that had a better booster and master. Anyone know?
"Rusty" is a 2009 JK, "X", 6spd, 2.5" Rock Krawler, Fox shocks, 33x12.5x15 Duratracs, AR Baja 15x8, Tuffy console, PIAA Fogs, 4:56 gears which are too low for this tire size, JCR front bumper, Warn winch.
Flingit1200s is offline
post #2 of 13 Old 05-28-2011, 07:31 PM
g4x4xgeoff
95 has a dual diaphram booster
Originally Posted by Hurley91 View Post
I could be drunk, high, raped and almost dead.... and I could still recognize it.
g4x4xgeoff is offline
post #3 of 13 Old 05-28-2011, 07:35 PM
glenn-91YJ
glenn-91YJ's Avatar
Here's a link to a post I wrote swapping a 2006 booster and MC in my 91.
http://www.jeepforum.com/forum/f12/0...my-yj-1177891/
Hope it helps.
Owning a "Renegade" means being "Different"!
"The greatest danger to American freedom is a government that ignores the Constitution."
-Thomas Jefferson
glenn-91YJ is offline
post #4 of 13 Old 05-28-2011, 07:37 PM
g4x4xgeoff
Fyi. i followed glen's thread.... but installed a 2000 cherokee into mine.
fantastic change.
post #5 of 13 Old 05-28-2011, 08:47 PM Thread Starter
Flingit1200s
2009 JK Wrangler
Thanks g. will see what I can find at the parts store tomorrow.
post #6 of 13 Old 05-29-2011, 04:32 AM
kloppk
I put a TJ dual booster & MC in my YJ.
WOW what a difference!
Baystate Jeepers
Deep Woods Extreme
New England 4 Wheelers
kloppk is offline
post #7 of 13 Old 05-29-2011, 05:16 PM
mbarrett1102
2010 JK Wrangler
I just redid the power booster and master cylinder for my 89...got the $100 one from advance and she works like a dream...just bleed the lines really well and replace all of the bleeder valves while you're at it...makes a huge difference. Even improved my engine performance
mbarrett1102 is offline
post #8 of 13 Old 05-29-2011, 10:22 PM
timatoe
timatoe's Avatar
Unless you're pressed for time or just really want new parts, you can get TJ or XJ boosters with the m/c all day on eBay for under $70.
timatoe is offline
post #9 of 13 Old 05-29-2011, 10:32 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Pep boys has the MC from a ford e-350 that bolted right up to my buddy's YJ. He said it was under $20 too!
Anticanman is offline
post #10 of 13 Old 05-30-2011, 08:53 AM
EZAces
I like my hydro booster out of a 86 chevy suburin 3/4 ton
EZAces is offline
post #11 of 13 Old 05-30-2011, 11:43 AM Thread Starter
Flingit1200s
2009 JK Wrangler
Well, I haven't got to the parts store yet but am thinking the 95 wrangler booster and master might be the easiest and take the least amount of fab.
post #12 of 13 Old 05-30-2011, 02:04 PM
TSEJEEPERS
Yes it is but the problem is finding them.
I can pretty much guarantee you will not be able to get them at the parts store.
I found mine at
http://www.autopartswarehouse.com/se...=Brake+Booster
I would call them to make sure they are in stock.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #13 of 13 Old 05-30-2011, 02:11 PM
jbolty
jbolty's Avatar
The TJ booster can be made to fit but it takes a little fab work. The bracket mount is not the same and the push rod length is different.
jbolty is offline
Brake Booster or Master Cylinder>? MikeUnlimited04 TJ Wrangler Technical Forum 2 03-19-2010 08:42 PM
Master cylinder/Brake booster question Smitty1 YJ Wrangler Technical Forum 0 05-10-2009 08:32 AM
Help with Brake Booster/ Master Cylinder Tompatt YJ Wrangler Technical Forum 13 10-27-2008 02:03 PM
Vanco Brake Master Cylinder/Booster goatboy YJ Wrangler Technical Forum 5 04-26-2008 10:28 AM
brake booster and master cylinder sandman'sjeep YJ Wrangler Technical Forum 3 06-28-2006 08:51 AM
