brake booster leak? tell me what you think - JeepForum.com
post #1 of 1 Old 06-04-2002, 11:27 PM Thread Starter
iamthemellowman
I happened to just be sitting in my jeep today with it idling with my foot on the brake. As i let up i heard a "whooooosh" noise from the booster area that would last as long as i held it in a particular position.. the whooshing went away once i pressed it to the floor or let up on the pedal. The noise is unmistakeably air rushing through a narrow opening.. however since it doesn't stop it makes me think it's a leak or am i just at a point where both a release valve is open as well as the vacuum feed? idle doesn't seem to change when i do this..
am i paranoid? or could this be a problem.
'92 YJ, 4.0L, rs5000, bds 2", 30" for now.
iamthemellowman is offline
Replaced Brake Booster - now brake lights stay on Viking TJ Wrangler Technical Forum 4 04-11-2017 06:46 PM
YJ Brake booster vacuum leak...??? Gooch YJ Wrangler Technical Forum 1 07-10-2009 05:15 PM
Brake Booster Leak?? nygiants57 YJ Wrangler Technical Forum 1 04-16-2008 10:19 AM
brake booster vacum leak ? rsgweld YJ Wrangler Technical Forum 5 07-12-2007 04:36 PM
Removed brake booster line and plugged it. Engine didn't die. Vacuum leak? DINOCAVE TJ Wrangler Technical Forum 3 10-11-2006 09:02 PM
