Brake booster itself gone bad, or check valve? - JeepForum.com
post #1 of 2 Old 04-03-2010, 02:11 PM Thread Starter
Neo1130
2015 JK Wrangler
Curious if one is more prone to failure than the other? I know the check valve is only about $6 with grommets so I can try that first. But the past month, every time I go out to start the Jeep, the brakes are ROCK hard. It's like the vacuum reservoir is leaking all of the vacuum out and causing the problem. This also happens about 2 hours after shutting the Jeep off. Doesn't cause drive-ability issues but I want to get this fixed before it gets bad and causes an accident.
Neo1130 is offline
post #2 of 2 Old 04-03-2010, 02:22 PM
Mark05059
personally for $6 I would do the check valve and if its not it then you will have a spare when you put in the new booster.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
Replaced Brake Booster - now brake lights stay on Viking TJ Wrangler Technical Forum 4 04-11-2017 07:46 PM
brake booster chef_kb YJ Wrangler Technical Forum 3 11-30-2009 03:17 PM
After brake booster install, brake lights are on??? HoustonRenegade YJ Wrangler Technical Forum 6 05-17-2009 08:49 PM
95 brake booster vs 93 brinoff YJ Wrangler Technical Forum 6 03-30-2009 08:41 PM
Brake booster Bad? Devildog985 YJ Wrangler Technical Forum 14 08-29-2007 08:21 PM
